Great news then :up:... lowest vid I saw in a Q9550 was like 1.2125
It's not the lowest.
My L847C219 is 1.2375 VID by the way. Still dialing in the voltages for 4Ghz :)
Ok guys here it is...
L847CO70
VID: 1.175
http://img216.imageshack.us/img216/1177/1175good.th.jpg
Well, reinstalling windows 7 now. Stupid raids.
Ended up getting the p5q turbo. I actually really like it so far! A lot better than the p5k in my server.
Also, chad, I know i'm not overclocking but my vid still dropped with speedstep turned off. I had to run a load to get a reliable number. Even then it changed every few seconds.
Hell when I was screwing with the crappy settings with the 750i I was able to start and run with a .9 something voltage!
If you want to know the vid use realtemp, it shows both min and max so theres no guessing.
Here is the real temp numbers. I am going to be selling this chip, since I will not be able to take full advantage of what it will offer under Phase or Ln2.
http://img30.imageshack.us/img30/1897/realtempa.th.jpg
Just got everything in and setup.
No clue how stable it is yet, I have no clue what i'm doing haha. I'm running intelburntest.
http://ludehawk.com/gallery/crap/q9550_40ghz.jpg
Nice Stock VID Guys
Mine Quad VID 1.2 In Core Temp
I Got UD3R Soon
hi there here is my Q9550. VID = 1.0875v
http://i29.tinypic.com/vdg4jk.jpg
a little oc :
http://i29.tinypic.com/11so5fa.jpg
My SETUP :
Processor: Intel Core 2 Quad Q9550 E0 @ 3.9GHz 1.23v
Motherboard: DFI LANParty UT P45-T2RS
Memory: Team Xtreem Dark PC8500 4GB Kit @ DDR2-1200 2.2v
Graphics Card: Manli GeForce GTX 295 1792MB GDDR3
Display: ViewSonic VX2835wm 28" Full HD WUXGA LCD Monitor
Audio: Xonar+Totem Mite-C+Denon AVR-2500+Energy ESW-8
Storage: 2X WD Raptor 74GB WD740ADFD @ RAID 0+WD Caviar 1TB
Optical Storage: ASUS DRW-2014L1T LightScribe DVDRW 20X SATA
HSF/Cooling: Xigmatek Thor's Hammer + Xigmatek XLF-F1253
Casing/PSU: iCute Super18-4GA-BB + Corsair HX750W
OS: Microsoft Windows Vista Ultimate x64 SP2
24/7 :D
http://img44.imageshack.us/img44/52/cpuv.png
P5Q-Deluxe 2201
vCore 1.5250v (LLC)
PLL: 1.58v
FSB Term.: 1.40v
vDimm: 2.04v
MCH: 1.42v
:up:
running @ 4GHz vcore @ BIOS 1.28v :
http://i26.tinypic.com/2cs8dxw.jpg
http://i27.tinypic.com/21kb8rr.jpg
a little update :
http://i28.tinypic.com/124yayt.jpg
Mines a 1.200 vid EO stepping, thinking of selling my current s775 kit and moving to i7.
http://img9.imageshack.us/gal.php?g=...221h59cpu1.png
I'm very happy of succeeding 3h of OCCT.
377*8.5 was stable with a very low vcore but 400*8 wasn't, I thought that the northbridge and the FSB were the cause, I set 1.26V for vnb and vtt, and 1.225 vcore (1.20V via cpuz and 1.17V load).
Ambiant T° : 27°C.
@magnum
there's No Picture showing up on your imageshack shot link...
fixed
Finnaly Bought Giga EP45-UD3R Today And Come To Me Tommorow+PSU 785 Watt Green
Cant Wait For End Of Week For Testing :D
Hey all, I'm planning on grabbing a Q9550 from my local microcenter and wanted to know if its possible to hit 4ghz with a P5Q-E (chipset rev. A2, if that matters)?
My validation :
http://valid.canardpc.com/show_oc.php?id=669234
As C1E is enabled, I had to run cinebench to get the real frequency, so this is the vcore under load (1.17V), whereas the idle vcore is around 1.20V.
I expect that many people will say that 3h of OCCT ain't enough, but for a use like mine, I think that 3h is enough.
http://www.noelshack.com/up/aaa/qehs...cbcc104813.png
you should have know problem booting up at 4.0ghz but you have to work to keep it stable..when you go to micro center ask the saleman to see if they all are the same batch numbers and how many he has pick a good 1 and please post your batch number and born on date for us..me and CincyRob on here got the same batch number and everything cause there was 13 left of the same at the time at are local micro center here in Cinncinnati..I wanna see if your store and my store got the same batch numbers by chance or close to it :yepp:
you should have the C1E disabled to get the correct freguency along with the CIET Function also or you will be throttled..i believe a test with intelburentest will
clear you of a stable chip if you pass the test after words run it thru a few hours of Orthos that's what..i do and Sandra to check my (mips) hey magnum
you should be sitting on 3.9 like me but it did take me some volts to get it stable there..I gotta work on lowering it down some best of luck my friend :up:
hey best of luck with the board you got.hey can you post a link to that PSU you are talking about getting also?
Q9550/Maximus II Formula
http://i237.photobucket.com/albums/f...r/MII_4GHZ.jpg
