Originally Posted by
Amurtigress
Hello,
I seem to have solved the basic stability issues for my system now.
So far, any moving away from a NB voltage of 1.32V meant an increasing frequency of prime errors.
Last night my PC was priming for 7 h 20 min. stable with no errors at a NB volt. of 1.28V, using the 24.14 Prime for 64 bit Windows. the only thing I changed was....
PCI-E Frequency from 100 Mhz to 101.
I ahve heard before that this shall have solved stability issues since the ASUS P5B series, but it never did for me. Anyway, for those who are suffering prime issues, enable this for a test and let us know what it does for you. I know it doesn't sound very plausable, but it is entirely possible that this is changing a strap within your intel chipset that makes it all stable.
This applies most likely to all Intel chipsets and ASUS boards since the P965 chipsets. For example, P965, X975, P31/33/35, X38, X48, P45, etc.
