I have Vista 64 Bit .
Any option i must use cause the program crashes during use ?
Memtest test 7 stresses ram and NB, if it errors out try upping the NB voltage and try to play a bit with the NB GTL values... How many passes of memtest are we talking about ? if you encountered this same behaviour on the P35 then it could well be that the CPU has issues mate... though 450FSB really isn't anything special... what happens if you try 445FSB ? ram at 1066Mhz
Disable the sound and the aero glass theme ( both options can be selected in the hyperpi program : top right )
I tried the modified bios in the other thread, helped a little, instead of crashing the mem test almost instantly it took 5 minutes.. :ROTF:
Hi! I've been reading the forums for a while now and I've come to the point where I need some guidance. I'm trying to get my E8400 rock stable at 4500Mhz. With my current setting it runs Prime95 64bit v25.8 build4 for 12h Small FFTs with no error, but fails Large FFTs just after about 2h and IBT on around the seventh loop. Here're my settings:
PS: Bios version - 1702Code:ASUS P5Q DLX Template :
JumperFree Configuration Settings
AI Overclock tuner: Manual
CPU Ratio Setting: 9
FSB Strap to North Bridge: 333
FSB Frequency: 500
PCI-E Frequency: 101
DRAM Frequency: 1002
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time: AUTO (52)
Write Recovery Time: 6
Read to Precharge Time: 3
2nd Information :
READ to WRITE Delay (S/D): 8
Write to Read Delay (S): 3
WRITE to READ Delay (D): 5
READ to READ Delay (S): 4
READ to READ Delay (D): 6
WRITE to WRITE Delay (S): 4
WRITE to WRITE Delay (D): 6
3rd Information :
WRITE to PRE Delay: 14
READ to PRE Delay: 5
PRE to PRE Delay: 1
ALL PRE to ACT Delay: 6
ALL PRE to REF Delay: 6
DRAM Static Read Control: Enabled
DRAM Read Training: Enabled
MEM. OC Charger: Enabled
AI Clock Twister: Moderate
AI Transaction Booster: Enabled
Common Performance Level [10]
Pull-In of CHA PH1: Enabled
Pull-In of CHA PH2: Enabled
Pull-In of CHA PH3: Enabled
Pull-In of CHA PH4: Enabled
Pull-In of CHB PH1: Enabled
Pull-In of CHB PH2: Enabled
Pull-In of CHB PH3: Enabled
Pull-In of CHB PH4: Enabled
CPU Voltage: 1.46250 (idle – 1.488v; load – 1.456v, according to CPU-Z)
CPU GTL Voltage Reference (0/2): 0.630
CPU GTL Voltage Reference (1/3): 0.630
CPU PLL Voltage: 1.54 (1.60v real)
FSB Termination Voltage: 1.28 (1.30v real)
DRAM Voltage: 1.90 (2.00v real)
NB Voltage: 1.22 (1.30v real)
NB GTL Reference: 0.580
SBridge Voltage: 1.10
PCIE SATA Voltage: 1.50
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Normal
NB Clock Skew : Normal
Advance CPU Settings
CPU VID: 1.250v according to coretemp and everest
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Enabled
EDIT: http://img299.imageshack.us/img299/4...fftstg7.th.png http://img353.imageshack.us/img353/2...sibtzb7.th.png
This thread is HUGE!!!
I finally ordered a P45 (P5Q-Deluxe) to see if I can get my quad (Q9550 E0 ES) higher than on my current board (P5K-Premium). Grabbed an open-box off NewEgg for $124 shipped. I also have 4x1GB Ballistx D9's.
Can anyone recommend the best BIOS for this setup?
Thanks!
Q6700
Ned help here,to hit 4.1+ GHZ bug whit strap mem,can only run whit 333 ??
There are also temporal error in bios 114.4c ,ned to Dis.. this in bios,This error has not been with E8600 or QX6850/bios 1702 ????
Hey Martin v.r I have a Q6700 too, what's your VID?
Also, could you share your P5Q DLX settings with me? I've been having occasional BSOD and I'm pretty sure they're not because of low vcore, there must be something else happening here.
can not start from 300 to 360 FSB whit this cpu in ?
VID:1.2250 Q6700 G0 @ 4GHZ 445x9
volt set in bios
vcore 1.531Xv =1.528V
PLL 1.52v
FSB 1.36v
NB 1.44v
MEM 2.36v 5-5-5-15 PLL 10 Cellshock PC8000 CL4 strap 333:mad:
Clock skev auto
Clock skev auto
Damn! You have a great VID! Mine is 1.3000
I'm currently at 425X8 which is enough for me. I got to 3800 once with my previous board (a gigabyte X38) but it wanted too much vcore for 24/7 operation at that frequency. Also tried 450X8 back then but it wanted 1.49v in BIOS to be stable.
So I satisfied myself with 3400 at the time, with 1.39v. But now with the P5Q DLX it doesn't want that many volts. I'm currently with 1.31825 set in BIOS at it is OCCT 15min stable, which is enough for me. The BSOD's must be coming from somewhere else - maybe because I switched the X38 for the DLX without reinstalling Vista 64 (yeah, maybe).
anyway, very soon I'll be cleaning up the box, put in the new backplate for the xigma and throw away the pushpins, and then, well, maybe I'll put windows 7 inside the animal and watch it squirm. Maybe the BSODs will go away. And maybe, just maybe I will try again 450X8 with less than 1.40v. That would be my goal after this.
In any case, currently I have everything voltage related in AUTO except VDIMM (1.80), because this board overvolts and my g.skills don't like too many juice, and vcore. I'm not sure about keying in 1.44 for NB and 1.36 for FSB. Looks like a lot to me... I dunno
an to 500x8 I use same volt set
PLL 1.52v
FSB 1.36v
NB 1.44v
MEM 2.36v 5-5-5-15 PLL 13 1201MHZ
Would you recommend a P5Q Deluxe over Maximus I Formula, for Q6600?
I have a Maximus i Formula running Q6600 @ 3,6 for 24/7 for a year now, and all I can say that its a very stable board! My friend asks me, that what would I recommend him now, Maximus Formula or P5Q Deluxe?
Are there any driver problems when I change my board from X38 to P45? The system will be stable, or I need to reinstall it?
reinstall it
Yeah, the DLX for what I could see so far, is a great board for overclocking. I can maintain lower vcores than with my previous X38. It's pretty damn stable, the loadline calibration works great and it's a cheap board!
I would also recommend you to reinstall everything. I did a board transplant (swapped the X38 for the DLX) because I couldn't spare the time for reinstallation due to work deadlines, and while everything ran smooth in the first two weeks, now I'm having occasional BSODs, probably due to USB driver conflicts. You should definitely resinstall everything to stay safe.
Hello, i have big trouble overclocking the ram memory in this board. i can only get the ram stable at 1082 mhz and any higher gives error in memtest. the board and cpu is stable at fsb 450.
the setup is:
P5Q deluxe
E8400
TWIN2X4096-8500C5DF
have anyone got any advice?
AI Overclock tuner: MANUAL
CPU Ratio Setting: 8
FSB Strap to North Bridge: 400
FSB Frequency: 411
PCI-E Frequency: 100
DRAM Frequency: 1096
DRAM Timing Control: MANUAL
1st Information :
CAS# Latency: 5
RAS# to RAS# Delay : AUTO (3)
Row Refresh Cycle Time: 60
Write Recovery Time: AUTO (6)
Read to Precharge Time: AUTO (3)
2nd Information :
READ to WRITE Delay (S/D): AUTO (7)
Write to Read Delay (S): AUTO (3)
WRITE to READ Delay (D): AUTO (5)
READ to READ Delay (S): AUTO 4)
READ to READ Delay (D): AUTO (5)
WRITE to WRITE Delay (S): AUTO (4)
WRITE to WRITE Delay (D): AUTO (7)
3rd Information :
WRITE to PRE Delay: AUTO (14)
READ to PRE Delay: AUTO (5)
PRE to PRE Delay: AUTO (1)
ALL PRE to ACT Delay: AUTO (6)
ALL PRE to REF Delay: AUTO (6)
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO (10)
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.20
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
FSB Termination Voltage: 1.24
DRAM Voltage: 2.02
NB Voltage: 1.24
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: AUTO
CPU Ratio Setting: Manual
CPU VID: Default
Execute Disable Bit: Disabled
i just used the 1702 bios. xp now just crashs on boot.... i tried changing loads of stuff, just doesnt have it... i have to put all settings back to default
man so much reading!! hopefully tomorrow or tuesday i will have mine in my hands!
Sorry if this has been answered here before, but I'm trying to find a good quality memory kit(s) that will go up to 8 Gb on this board, but not cripple my OC. Anybody try this? If so, any recommendations?
My friend runs 2 sets of OCZ Reaper 2x2GB DDR1066. It runs fine with 8GB and he's running it at 1066 but has not tried to push it yet, he just set 2.14V and its been rock stable. (everthing else is OC'd just not the ram, so it will at least hit that minimum.
On a side not...Some help please. I just built a P5Q-D rig last night with the above ram and a Q9650. I"m getting constant BSOD in any game, and even a couple from Vista64 desktop. I've tried 3 different bioses, ram timming is set correctly as well. I have read somethigns about setting "cpu margin enchancement' to performance for quads to fix some BSOD issues...anyone done that here?
Thanks for the recommendation...I've looked on Newegg, and the price is pretty good too.
As far as your question goes, yes, I run CME switched to performance mode on my system...otherwise, it's unstable. So you should certainly give that a try. Of course, nobody has any idea what CME is, but for some configurations, that's the difference stable and unstable rig.
I run cme in performance mode, but just to stretch the last bit of stability out of my setup. Optimized was fine for me up to 480fsb. I would try the official 1406, Ket's bios are good but its still worth a try. I'd also suggest running Memtest in windows with 4 instances to rule out the ram.
Larry
