Good work and :down: to the "back ups" posted.
Just wait for George's back-up, he has played the game many times... :rofl:
Still working at getting better @ the game :D
http://i.imgur.com/XVnFLbo.jpg
http://i.imgur.com/HOdOSO9.jpg
Ran R11.5 at the end of the session and was surprised at the results, will get a proper WR for R11.5 tomorrow when things dry once again.
Wanted to say thanks to Davis for the GTX 2's, they made this soooo much easier.
Thanks Dan, on to more 771 gear
cpu #2
http://i.imgur.com/iPpV0m3.png
What's the max validation on this one? Around 6.4 GHz?
PS: Happy Easter! :)
https://i.chzbgr.com/maxW500/6165095936/h7468CEEF/
While moving found I still have my old P4P800SE and OCZ Booster. Saw these floating on eBay and decided to grab them. Anybody know if these are TCCD or the bad stuff that came afterwards?
http://i210.photobucket.com/albums/b...psrmffs3lp.png
F(l)uck XTU! I hope I never have to bench this setup again XD
Prep time > Run time
http://i.imgur.com/JKPMeAz.png
Relevant sauciness
http://i.imgur.com/9SA2BVt.gif
1.27V VID is pretty bad, but those chips can also be limited by FSB walls, so a bad VID chip can still be better than a chip with a promising VID as long as it has a higher FSB wall.
Do you have an Asus CT-479 adapter as well?
No idea what's the difference between version 1.0 and 1.1. :shrug:
TCC5 binned for the same spec as TCCD shouldn't be a lot worse than TCCD though. Will you test the setup again?
You nailed it! :up:
Worthless to the team, but I posted this last night:
http://hwbot.org/submission/2534582_
Not bad for 45nm...tried 1860 MHz but the phone crashed.
Not bad, you even received some global points! :up: :D
Not anymore, sold off a lot of that platform years ago. P4C fully modded, think 730, special G Skill binned BH-5, CT-479 adapter (attempted Hipro mod, didn't go well :p:), full modded x850xt PE and modded full Cu Zalman. If I had means for sub zero, could have done some real damage.
Going to get an adapter for this platform and 771 adapter for my REX. Start doing some old school phase benching in the coming months.
Too bad, I saw an CT-479 on ebay.de today, but I was too slow at the end of the auction and it sold for 12,60€. Would've been nice to have it. :(
I remember the mods hipro did to his 479 setup, crazy stuff!
As far as I know X48 and the 771 mod don't play well together, that's why no one is using a REX for their tests. Try to find a cheap P35 or P45 board and don't risk killing your REX, they're too precious. Maybe George can chime in with more info, as he has done some testing with 771 chips.
What Dan said:yepp:
Not a good idea to cut up a REX unless you plan to run a X33xx series Xeon and not the X54xx models. I have seen X48 chipsets work with 771 quads so it is possible, just search the 771-775 thread at OCN, I read like half of it the other day lol
Also be sure to update your bios with the correct microcode to "unleash the full POWAH!" :p:
News at HWBOT: l0ud_sil3nc3 one-ups W1zerty and sets new 2xCPU XTU record with Core i3 4340 at 4070 Mhz :clap:
If you could run a 3 core setup that would be nice! :up:
PS: Looks like it'll be hard to get to the second rank this year... Moderator Ranking 2014 - Current Standings :rofl:
Could and would are two different things! XD
There are lots of 2x and 3x core global and team points to be had. I still have Daveburt714's 8 GHz FX-8120 as well. I hope to send it home with him including a nice hunk of machined copper but he wants me to hold onto it for now.
Sorry, you know I'm not a native English speaker! :p:
Well, for 3x and 5x core AMD is the only way to go, but for 2x you need at least 3 different setups, none of which are AMD based. Clarkdale for WPrime ( and HWBOT Prime ), Wolfdale for HWBOT Prime and Westmere for Cinebench. More points could be had if you focused on 1x core with an AMD setup.
By the way, good to see you again.
#2 of 6
http://i.imgur.com/XtRG1oW.jpg
http://i.imgur.com/UvgDjLu.png
X58 32M warmup (cpu@LN2 / memory@air)
http://i.imgur.com/FXlKuwp.png
Any tips on getting high bclk on X58, I could not boot 250 even with slow mode.
Posted a wanted thread but may get more attention here, anybody have an old AOpen i975Xa-YDG laying around? ;) :cool:
Are all those chips L3014? :shocked:
Congrats for taking back the 1x record! ;)
What did you try so far? Is this Brian's old chip or a random chip? PCIe clock?
I saw it, but I'm afraid they're very rare nowadays. I've looked for it from time to time as well, but it seems impossible to find. Maybe you're better off trying to find another CT-479 adapter. Anyway, good luck! :up:
