CPU voltage differs from CPU to CPU mate, that's for you to find out. If your quad runs happily at 1.25Vcore set it like that...
Templates are what works for once's specific hardware... I would just take them as a guideline and would always start a bit lower on the volts ( surely FSB term voltage ) and work ya way slowly up eg from 450 to 475 or whatever FSB you require.
1) it's like dropping a half on the Performance level so eg you set PL 9 and with all pull ins enabled you should get 8.5PL in performance... doesn't work on all biosses and differs from board type to board type
2) GTL tuning could be required : test ya CPU with small FFT and if eg it's always the same core that caps out try lowering the first value till it gains in stability (write that figure down), at a certain moment it will become unstable again (write it down) and go half way for the final setting... GTL tuning can take some but is a MUSt with modern quads with high FSB action
3) I never had to use PCI E voltage this high, I always lef tit on AUTO , but some users claimed it overvolted ( I don't even know where to read this value on these boards via a DMM, think it is pure speculation on their behalf)
Don't think it has got anything specific to do with the board mate, maybe more a setting or something with ya rams or PSU not being 100% okay or compatible. I even gamed at 550FSB daily and never had this freezing issue you seem to have... You had this on the MF II too and not on the Commando...
If you think that your CPU puts out 29°C at 4.4Ghz either you are running chilled water or your temp read outs are completely bugged... 5ghz daily is a no go, forget about that unless running phase cooling... In your case I would try to stabilise 9 x 500 with 1600Mhz ram speed :up:
