thanx....up sory e84 with ASUS P5Q, just 4 compare u'r mighty chip...
but the ddr 1200 use UD3R
I found out the reason why anything inbetween 480fsb and 500fsb wasn't stable... it was RAM. Strange...
It seems so picky with what timings can be set. At 467fsb with ram at 1868mhz 8-8-8-22, trfc 59, it ran blend overnight (8hours or so), using custom 3200mb of memory. But at 485fsb with 1940mhz on ram, the timings needed to be set to 10-10-10-28, trfc 84, to at least run blend for 10mins (i didn't test further). Yet 500fsb with ram at 2000mhz, with 8-8-8-24, trfc 84, it ran for an hour.... the ONLY thing different was that cmd rate was at 1n, which i can't set myself, it never sticks when i set in bios, only at 500+ it auto sets to 1n.
Is there something i'm missing with DDR3? I'm not too familier with RAM overclocking, i always thought it was pretty straight forward :shrug: Can anyone share their experiences and tips with DDR3? i would really appreciate it :)
Oz
Oztopher I am struggling on my ddr3 board as well, what are your complete settings including GTL refs?
Hey guys so I have a gigabyte e45-ud3p and an intel q6600 quad SLACR. I need some help with overclocking on the unit. I am on Phase change for the CPU cooling wise. With 2 spot cools over the NB and the RAM. I have a bench table, so everything is open air cooling also.
My Questions:
What are the safe voltage areas for my particular setup? Am I safe where I am at now? Can i go higher in some areas?(See Log of Settings)
What are some settings I can try for my memory. I dont quite understand the ratios anymore and Im not sure if the few attempts ive had BSOD because ive set memory to high or something. I have GSKILL F2-8500CL5D-4GBPI PC2-8500 5-5-5-15 2.1.
Is there anything you can see in my settings that I should change?
The settings:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..............: [A]
CPU Clock Ratio ......................: [9X]
x Fine CPU Clock Ratio................: +0.0
CPU Frequency ........................: 4.05GHz( 450x9)
********** Clock Chip Control ********
>>>>> Standard Clock Control
CPU Host Clock Control................: [Enabled]
x CPU Host Frequency(Mhz).............: [450]
PCI Express Frequency(Mhz)............: [100]
C.I.A.2...............................: [Disabled]
>>>>> Advanced Clock Control..........: [Press Enter]
CPU Clock Drive.......................: [800mV]
PCI Express Clock Drive...............: [900mV]
CPU Clock Skew........................: [ 0ps]
MCH Clock Skew........................: [ 0ps]
******** DRAM Performance Control ********
Performance Enhance...................: [Standard]
Extreme Memory Profile(X.M.P.)........: [Disabled]
(G)MCH Frequency Latch................: 333
System Memory Multiplier (SPD)........: [2.00C]
Memory Frequency(Mhz).................: 1080
DRAM Timing Selectable (SPD)..........: [Auto]
****** Motherboard Voltage Control ******
Voltage Types..........Normal...........Current
>>> CPU
Load-Line Calibration.................: [Enabled]
CPU Vcore..............1.27500V.......: [1.5]
CPU Termination........1.200V.........: [1.38]
CPU PLL................1.500V.........: [1.61]
CPU Reference..........0.760V.........: [.914]
>>> MCH/ICH
MCH Core...............1.100V.........: [1.4]
MCH Reference..........0.760V.........: [.914]
MCH/DRAM Reference.....0.900V.........: default
ICH I/O................1.500V.........: [1.570V]
ICH Core...............1.100V.........: [1.200V]
>>> DRAM
DRAM Voltage...........1.800V.........: [2.18V]
Everything else auto or default
Hey mate, these are my settings so far for 467x9: (8hours or so stable on prime blend) Obviously some things will be different depending on how good ur chip, board and ram are.
Robust Graphics Booster ...................: Auto
CPU Clock Ratio ...........................: 9x
Fine CPU Clock Ratio.......................: --
CPU Frequency .............................: 4203Mhz
Clock Chip Control
CPU Host Clock Control.....................: [Enabled]
CPU Host Frequency (Mhz) ..................: 467Mhz
PCI Express Frequency (Mhz) ...............: 101
C.I.A. 2...................................: Disabled
CPU Clock Drive............................: 800mv
PCI Express Clock Drive....................: 900mv
CPU Clock Skew (ps)........................: 0ps
MCH Clock Skew (ps)........................: 0ps
Performance Enhance........................: [Turbo]
(G)MCH Frequency Latch.....................: [333]
System Memory Multiplier ..................: 4.00B
Memory Frequency (Mhz) ....................: 1868Mhz
DRAM Timing Selectable ....................: [Manual]
Standard Timing Control
CAS Latency Time...........................: 8
tRCD ......................................: 8
tRP........................................: 8
tRAS.......................................: 22
Advanced Timing Control [Press Enter]
tRRD.......................................: 4
tWTR.......................................: 4
tWR........................................: 8
tRFC.......................................: 59
tRTP.......................................: 4
Command Rate (CMD) ........................: Auto
Channel A Timings Settings [Press Enter]
Static tRead Value.........................:7
tRD Phase0 Adjustmen.......................:Auto
tRD Phase1 Adjustment......................:Auto
tRD Phase2 Adjustment .....................:Auto
tRD Phase3 Adjustment......................:Auto
Trd2rd(Different Rank).....................:Auto
Twr2wr(Different Rank).....................:Auto
Twr2rd(Different Rank).....................:Auto
Trd2wr(Same/Diff Rank).....................:Auto
Dimm1 Clock Skew Control...................:+200 ps
Dimm2 Clock Skew Control...................:Auto ps
DDR Write Training ........................: Disabled
DDR Write Leveling ........................: Disabled
Channel A Driving Settings [Press Enter]
Driving Strength Profile...................:Auto
Data Driving Pull-Up Level.................:Auto
Cmd Driving Pull-Up Level..................:Auto
Ctrl Driving Pull-Up Level.................:Auto
Clk Driving Pull-Up Level..................:Auto
Data Driving Pull-Down Level...............:Auto
Cmd Driving Pull-Down Level................:Auto
Ctrl Driving Pull-Down Level...............:Auto
Clk Driving Pull-Down Level................:Auto
Channel B Timings Settings [Press Enter]
Channel B Driving Settings [Press Enter]
Voltage Type.………... Normal
CPU
Load Line Calibration......................: [Enabled]
CPU Vcore....................1.225v........: v 1.38750
CPU Termination….............1.200V*.......: v 1.24
CPU PLL......................1.500V*.......: v 1.50
CPU Reference................0.760V*.......: v 0.785
MCH/ICH
MCH Core.....................1.100V........: v 1.24
MCH Reference................0.800V........: v 0.785
MCH/DRAM Ref.................0.750V........: v 0.940
ICH I/O......................1.50V.........: v 1.50
DRAM
DRAM Voltage.................1.500V........: v 1.90
DRAM Termination.............0.750V........: v 0.940
Channel A Data Reference.....0.750v........: v 0.940
Channel B Data Reference.....0.750v........: v 0.940
Channel A Address Reference..0.750v........: v 0.940
Channel B Address Reference..0.750v........: v 0.940
Advanced Settings
HDD S.M.A.R.T. Capability..................: [Disabled]
CPU Multi-Threading........................: [Enabled]
Limit CPUID Max. to 3......................: [Disabled]
No-Execute Memory Protect..................: [Disabled]
CPU Enhanced Halt (C1E)....................: [Disabled]
CPU Thermal Monitor 2(TM2) ................: [Disabled]
CPU EIST Function..........................: [Disabled]
Virtualization Technology..................: [Disabled]
Can someone give me some info please, I want to know if its possible to run this memory cooler with the UD3P mobo without any clearance issues with the heatsinks
http://www.newegg.com/Product/Produc...82E16835116021
My computer has been unhappy lately. When I enable LLC, the voltage stays above 1.4v almost always. When I disable, it drops as low as 1.392.
The problem is that I'm getting higher temps with the higher voltage (46*C or more idle) instead of 40. I keep reading about people having vCores in the low 1.300's, how can I do that? (or is that what happens when you get a "good chip"?)
I'm also getting blue screens here and there and games have frozen on me a few times (I was playing Batman AA and it froze) I'm having a hard time figuring out if this is the GFX card's problem though...
Any suggestions on where to start?
Is PLL set to 1.5 keeping my vCore higher than what I set it to with LLC enabled?
Hi Guys
I need you to help me .
I Have EP45-UD3R Rev 2.1 // Q9550 E0
I want to know what is the best bois should i use with my Ep45 , Im using the F11 .. Also i want to know if it safe to downgrade the bois or not ??
because i noticed a bug in the F11 bois
When i choose some volt configration ( speially the CPU Ref Volt , MCH Reference Volt) some value in bois then open ET6 in Windows i Relaize that the Volts had been changed wo be less that i chose
for example when i choose CPU Ref Volt 0.85 i open ET 6 then find it 0.76 !! so wut is the real one ?
but when i set these volt to be .85 in ET6 i got more stabilty in overclocking
So is this normal ???
Thanks guy , waitng for you help
thats not a bug thats the way it works.here read this.
http://www.xtremesystems.org/forums/...postcount=1157
the line in red is what ET6 will report.Code:
ET6...../0.730 / 0.745 / 0.760 \ 0.785 \ 0.800
vtt 1.20 0.730 / 0.745 / 0.760 \ 0.785 \ 0.800
vtt 1.22 0.742 / 0.757 / 0.772 \ 0.797 \ 0.812
vtt 1.24 0.755 / 0.770 / 0.785 \ 0.810 \ 0.825 CPU reference value in bios
vtt 1.26 0.768 / 0.783 / 0.798 \ 0.823 \ 0.838
vtt 1.28 0.780 / 0.795 / 0.810 \ 0.838 \ 0.850
vtt 1.30 0.793 / 0.808 / 0.823 \ 0.848 \ 0.863
vtt 1.32 0.806 / 0.821 / 0.836 \ 0.861 \ 0.876
vtt 1.34 0.818 / 0.833 / 0.848 \ 0.873 \ 0.888
vtt 1.36 0.831 / 0.846 / 0.861 \ 0.886 \ 0.901
vtt 1.38 0.844 / 0.859 / 0.874 \ 0.899 \ 0.914
vtt 1.40 0.856 / 0.871 / 0.886 \ 0.911 \ 0.926
vtt 1.42 0.869 / 0.884 / 0.899 \ 0.924 \ 0.939
vtt 1.44 0.882 / 0.897 / 0.912 \ 0.937 \ 0.952
vtt 1.20 0.720 / 0.740 / 0.760 \ 0.800 \ 0.840
vtt 1.22 0.732 / 0.752 / 0.772 \ 0.812 \ 0.852
vtt 1.24 0.745 / 0.765 / 0.785 \ 0.825 \ 0.865 MCH reference value in bios
vtt 1.26 0.758 / 0.778 / 0.798 \ 0.838 \ 0.878
vtt 1.28 0.770 / 0.790 / 0.810 \ 0.850 \ 0.890
vtt 1.30 0.783 / 0.803 / 0.823 \ 0.863 \ 0.903
vtt 1.32 0.796 / 0.816 / 0.836 \ 0.876 \ 0.916
vtt 1.34 0.808 / 0.828 / 0.848 \ 0.888 \ 0.928
vtt 1.36 0.821 / 0.841 / 0.861 \ 0.901 \ 0.941
vtt 1.38 0.834 / 0.854 / 0.874 \ 0.914 \ 0.954
vtt 1.40 0.846 / 0.866 / 0.886 \ 0.926 \ 0.966
vtt 1.42 0.859 / 0.879 / 0.899 \ 0.939 \ 0.979
vtt 1.44 0.872 / 0.892 / 0.912 \ 0.952 \ 0.992
BTW radaja, congrats on that q9650. You got a great chip there, you waited a long time for one.
thanks.problem is since i dont have time to really
OC right now im just going to sell it.:(take a couple of months
off,its a shame too cause your right it did take me awhile
to find it.
Does this motherboard have the right sound connections for an X-5500 speaker system? What kind of speakers can it support?
I bought me a UD3P as a backup board sense they so low in price now from Newegg with (Free Shipping).I gotta say. I kinda like so far so good on the Oc'ing right now
http://img402.imageshack.us/img402/2...4250ghz.th.jpg
http://img134.imageshack.us/img134/8629/everestg.th.jpg
http://img524.imageshack.us/img524/3...tsensor.th.jpg
Some new BIOS's released.:D
http://forums.tweaktown.com/f69/giga...st-bios-28441/
F10I, Yay for having quick boot :up:, boo for still having lower reads and higher latency. :down:
What do you guys think about the EP45T-UD3LR? will the 4 pin ATX and 4 phases hold back the same stable OC I got on the EP45-UD3R?
I read the new P45 bioses unlock 0.5 multi, someone with Q9450 8x333 can use the 0.5 multi, so he get 8.5x333. can someone confirm that?
again.....UD3R.......
HIGH VID i got.........:(
http://i50.tinypic.com/2rh5kkh.jpg
