I've never tested auto setting:(
hmm... i dont want to read 200 pages...
Simple question...
Is this motherboard any good? for OC'ing and Quad Q6600 cpu?
Ok i can boot with 333 strap and trans booster disabled.I also run everest cache and menory benchmark.With Trans booster disabled i seem to have a slight overall increase on read/write/copy benchamarks over the auto setting.
Now about the 47 min prime95 hung up.I raised the NB Volt @ 1.51 in bios (1.55 in everest).I now got a bsod around 49 min.So i think i ll have to raise it more.The only good thing is that NB temp according to Everest didnt raise at all.48C under full load.
Going to test more...Too much trouble for just 3,4Ghz:shakes:
Here I am stable DDR2-1128 5-5-5-15 FSB Strap 400
:woot:
http://aycu15.webshots.com/image/381...8131510_rs.jpg
Evest Memory bench: (write could be better...)
http://www.xtremesystems.org/forums/...1&d=1199668467
i'm almost there (play with vtt ref.nb.pll.vtt)
any suggestion?
my settings
vcore 1.75(temp OK)
fsbt(vtt) 1.7
pll 1.8
nb 1.8 (temp OK)
NOT 100% just for super pi 1m
:confused: :confused: :confused: :confused: :confused:
care to explain why my board bios is different from yours?
http://pages.videotron.com/rez/bios.jpg
that last empty line is where i saw the hyperthreading option. There is a slight chance that what i saw was SpeedStep, not HyperThreading. The value was ENABLED when i saw it. It did have "intel" written, that i am 100% sure. There once was a time when i did have the "cpu ration control" option, maybe it was with another bios... BTW, none of my settings were left to "auto".
The 907 BIOS did change a number of options. Are you two running the same version?
Mine got Speedstep oO, after switching between 0802/0903/0907 on the last line
ReZ your not Insane idd LOL, I got this speedstep ,I just remembered after I performend the BIOS flash IN windows I thought to flash from 0907 to 0802, then I reflashed again with 0802 with EZ-flash, and suddently there was a speedstep LOL, which was never before there, but now it is still there, I could take a picture later on if u want
Oke I just found out how to get "" Intel Speedstep" under cpu configuration. This option appears as soon u put CPU ratio : Auto , so not 8x or 9x then u look @ cpu config there u see Intel speedstep:X
You're right!
thanks mate.
u put me into thinking , np m8 ;)
ASUS's FTP site been taken down? Should have new BIOS soon right?
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...aximus_Formula
Hi,
try this: :-)
ftp://ftp.asus.com/pub/ASUS/mb/socke...aximus_Formula
Greets,
Cb
yea it is about time for a new BIOS!
Good eyes ReZ & mc2k. I see what you guys are talking about: When the multiplier is set to auto in Extreme Tweaker in BIOS 0802, the "Intel Speedstep" option is all of a sudden present in the "Advanced" Menu under CPU Config menu... You weren't seeing ghosts after all. My question is to you guys with newer BIOS's is, is the same true for you guys. I'm on 0802 now. When I got this board, the newest release was 0901, and that's where I started. Lotsa work to get back to older BIOS's with us peeps with 64bit OS's...
