I seemed to have hit a FSB wall. I get 4.15GHz(13x319) and it passes Prime95 for an hour with temps only low 50's. as soon as I go 13x320 it won't post at all and just beeps at be and resets itself at default clocks of 13x200. I even tried lowering the multiplier slowly down to x6 and still no post. I was hoping there is a trick to get a little more, or maybe a setting I overlooked.
Here's my BIOS settings:
I also tried setting (G)MCH to 333 too see if the next boot strap would help and nothing at x6 multiplier as well.Code:*** GigaByte GA-EP45-UD3R BIOS F9 ***
Robust Graphics Booster: Auto
Cpu Clock Ratio: 13.0
*** Clock Chip Control ***
CPU Host Clock Control: Enabled
CPU Host Frequency(MHz): 319
PCI Express Frequency(MHz): 100
C.I.A.2: Disabled
*** Advanced Clock Control ***
CPU Clock Drive: 800mV
PCI Express Clock Drive: 900mV
CPU Clock Skew: 0ps
MCH Clock Skew: 0ps
*** DRAM Performance Mode ***
Performance Enhance: Turbo
(G)MCH Frequency Latch: 266MHz
System Memory Multiplier (spd): 3.00A
DRAM Timing Selectable (spd): Manual
*** Standard Timing Control ***
CAS Latency Time: 6
tRCD: 6
tRP: 6
tRAS: 18
*** Advanced Timing Control ***
tRRD: Auto
tWTR: Auto
Twr: Auto
tRFC: Auto
tRTP: Auto
Command Rate (CMD): Auto
>>>Channel A: All Auto
>>>Channel B: All Auto
*** Motherboard Voltage Control ***
>>>CPU
Load-Line Calibration: Enabled
CPU Vcore: 1.37500V
CPU Termination: 1.3600
CPU PLL: 1.570V
CPU Reference: 0.886
>>>MCH/ICH
MCH Core: 1.300V
MCH Reference: 0.901
MCH/DRAM Reference: Normal
ICH I/O: Normal
ICH Core: Normal
>>>DRAM
DRAM Voltage: 2.200
DRAM Termination: Normal
Channel A Reference: Normal
Channel B Reference: Normal
*** Advanced BIOS Features ***
C1E: Disabled
EIST: Disabled
Thanks for any help
-=Mark=-
