Probably the drive just needs extra overprovisioning. Those 60GB are enough just to make the drive enter in MLC-1 mode. To keep it there, I would guess you would need to use even more over provisioning, like 70-75GB.
Secure erase fixed it:
Attachment 128683
At what point did it start slowing down?
(history might repeat itself)
Here are todays update:
m4
1264,4222 TiB
5272 hours
Avg speed 74.35 MiB/s.
AD 147 to 144
P/E 21747.
C3 4457
CE 58
MD5 OK.
Reallocated sectors : 00
http://www.diskusjon.no/index.php?ap...tach_id=498120
Intel X25-M G1 80GB
813.02 TiB
24559hours
Reallocated sectors : 134 to 153
Available Reserved space: 45 to 44
MWI= 169 to 152
MD5 =OK
31.39 Mi/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498119
Intel X25-E 64GB
556.88 TiB
1740-30=1710 hours
Available Reserved space: 100
MWI= 96
MD5 =OK
91.16 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498121
Samsung 830 256GB Day 125
(GiB) 3,071,152
(TiB) 2,999
(PiB) 2.95
(Avg) 298.87 MB/s
(B1) Wear Leveling Count: 13,304
(B6) Erase Fail Count: 9
(05) Reallocated Sectors: 36864
(POH) 3045
The drive actually has 3012 TiB in LBA writes. I lost 13 TIB in ASU along the way.
Intel 330 120GB
600.30TB Host writes
2.12TiB Host reads
Reallocated sectors : 05 24 +2
Available Reserved Space : E8 100
MWI 30
[B5] 12
[B6] 12
[F1] Total LBAs Written 19670569
[F2] Total LBAs Read 69534
[F9] Total NAND Writes 433332GB // ~423TiB
POH 1451
MD5 OK
125.21MiB/s on avg (~324 hours)
Kingston SSDNow 40GB (X25-V)
1141.37TB Host writes (37400662*32)
Reallocated sectors : 05 65
Available Reserved Space : E8 98
POH 10186
MD5 OK
33.34MiB/s on avg (~324 hours)
Sandisk Extreme G25 - 120gb - Day 49
Drive hours: 1173
ASU GiB written: 506,710.51 GiB (494.83 TiB)
Avg MB/s: 125.81 MB/s (7.19 hours)
MD5: OK
Host GB written (F1): 510,518 GiB (498.55 TiB)
NAND writes (E9): 381,058 GiB (372.13 TiB)
Retired Block Count (05): 4 raw
Failure count (AB, AC): 1 program, 1 erase
Raw Error Rate (01): 109 normalized
Media Wearout Indicator (E7): 10 normalized
Wear Range Delta (B1): 3 raw
Reported Uncorrectable Errors (BB): 0 raw
Vertex 4 - 50% OP - 128gb - PAUSED
Drive hours: 101
ASU GiB written: 61,811.98 GiB (60.36 TiB)
Avg MB/s: 0 MB/s (0 hours)
MD5: OK
Host GB written (E8): 62,941.02 GiB (61.47 TiB, 131996886814 raw)
Raw Read Error Rate (01): 5 raw
Reallocated Block Count (05): 0 raw
Remaining Life (E9): 84 normalised
I can't seem to keep the vertex 4 out of storage mode. Secure wipe only helped for half an hour or so, then performance dropped again. I'll try a firmware reflash followed by another secure wipe. See if that helps.
Strange thing is that it ran fine for 3 days .....
If I can't get this working right, I may need to abandon breaking this V4 ... which would mean I would need to go find another victim in its place.
So, having secure erased it performs as expected in benchmarks?
Can you get it to perform in benchmarks once it has entered the so called storage-mode. (by normal means, like, i.e. by trimming a large file,...)
It always perfoms fine in benchmarks ... benchmarks simply don't push enough writes to the drive.
You see my graphs above showing performance degredataion while running ASU ... the first 10gig or so of writes was always ultra-quick, even when the run was being slowed significantly by the storage mode later in each cycle
My ASU runs always keep 5 gig free, and I am running a 61000meg parition.
But I'll try smaller partitions if I have problems again (I've just reflashed and secure erased, then ran WEI after creating partition to make sure windows knows it is an SSD and to use TRIM.
My rig had frozen 2 hours ago, can't find what caused it, nothing in the EventLog.
I suspect it was caused by the X25-V as there were 0 files in the test folder, as in, all files were deleted and just about to start a new loop.
Both drives look to be OK, I'll keep an extra eye on the rig this evening.
Intel 330 120GB
604.10TB Host writes
2.22TiB Host reads
Reallocated sectors : 05 26 +2
MWI 29
[B5] 13
[B6] 13
[F1] Total LBAs Written 19795323
[F2] Total LBAs Read 72844
[F9] Total NAND Writes 436080GB // ~426TiB
POH 1460
MD5 OK
125.29MiB/s on avg (~3 hours)
Once restarted, the 330 quickly threw a few reallocated sectors.
Attachment 128713
1142.45TB Host writes (37435802*32)
POH 10195
MD5 OK
38.44MiB/s on avg (~3 hours)
Attachment 128712
Only 40 more hours to 3PiB. That feels like a monumental number, but that would be the equivalent of a 64GB drive hitting 775TiB -- ie 3/4ths of a PiB.
Samsung 830 256GB Day 126
(GiB) 3,098,472
(TiB) 3,025
(PiB) 2.97
(Avg) 299.06 MB/s
(B1) Wear Leveling Count: 13,422
(POH) 3071
The 830 actually has 3040TiB on it, so a little over 24 hours from now should be 3PiB
About 14 hours later...
Intel 330 120GB
609.96TB Host writes
2.24TiB Host reads
Reallocated sectors : 05 31 +5
MWI 29
[B5] 15
[B6] 16
[F1] Total LBAs Written 19987316
[F2] Total LBAs Read 73298
[F9] Total NAND Writes 440309GB // ~430TiB
POH 1474
MD5 OK
125.21MiB/s on avg (~17 hours)
This time, B5 is not equal to B6.
1144.07TB Host writes (37488837*32)
POH 10209
MD5 OK
35.39MiB/s on avg (~17 hours)
m4
1276.6606 TiB
5320 hours
AD 144 to 137
P/E 21954.
C3 4457
CE 58
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=498318
Intel X25-M G1 80GB
818.04 TiB
24607 hours
Reallocated sectors : 153 to 201
Available Reserved space: 44 to 41
MWI= 152 to 135
MD5 =OK
31.07 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498319
Intel X25-E 64GB
572.00 TiB
1788-30=1758 hours
MWI= 96
MD5 =OK
91.22 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498317
Mtron Pro 7025 32GB
Paused until new firmware is updated.
Samsung 830 256GB Day 127
(GiB) 3,122,132
(TiB) 3,048
(PiB) 3.00
(Avg) 298.61 MB/s
(B1) Wear Leveling Count: 13,524
(POH) 3094
It's behaving nicely :)
I'll make sure to check what chips are used on both drives. (eventually)
Intel 330 120GB
620.21TB Host writes
2.26TiB Host reads
Reallocated sectors : 05 33 +2
MWI 27
[B5] 16
[B6] 17
[F1] Total LBAs Written 20323087
[F2] Total LBAs Read 74149
[F9] Total NAND Writes 447708GB // ~437TiB
POH 1497
MD5 OK
125.20MiB/s on avg (~41 hours)
1146.79TB Host writes (37578229*32)
POH 10233
MD5 OK
34.12MiB/s on avg (~41 hours)
Sandisk Extreme G25 - 120gb - Day 51
Drive hours: 1221
ASU GiB written: 527,275.97 GiB (514.9179.83 TiB)
MD5: OK
Host GB written (F1): 531,263 GiB (518.81 TiB)
NAND writes (E9): 396,545 GiB (387.25 TiB)
Raw Error Rate (01): 100 normalized
Wear Range Delta (B1): 4 raw
Drive hours: 101
ASU GiB written: 62,800.31 GiB (61.33 TiB)
MD5: OK
Host GB written (E8): 63,967.47 GiB (62.47 TiB, 134149509504 raw)
My last attempt to get the vertex 4 working in performance mode only failed after 20 minutes or so. I also tried increasing the time between runs to 30 seconds to give the drive more recovery time, but that didn't help.
I am not testing with a 50,000 Megabyte partition, which is about what an enterprise focused SSD would get on a 64gig SLC drive.
It's too bad about the V4. I honestly think the 128 is one of the most interesting drives on the market, but not giving end users a choice to stick with pre 1.4fw if they so choose is a bit off-putting. 1.4+ is not for everyone IMHO.
Both drives produced a few reallocations.
Intel 330 120GB
623.95TB Host writes
2.27TiB Host reads
Reallocated sectors : 05 35 +2
MWI 27
[B5] 17
[B6] 18
[F1] Total LBAs Written 20445743
[F2] Total LBAs Read 74490
[F9] Total NAND Writes 450411GB // ~440TiB
POH 1506
MD5 OK
125.15MiB/s on avg (~49 hours)
Attachment 128827
1147.79TB Host writes (37610723*32)
Reallocated sectors : 05 67 +2
POH 10241
MD5 OK
33.95MiB/s on avg (~49 hours)
Attachment 128824
Attachment 128825
m4
1282.7254 TiB
5344 hours
Avg speed 74.38 MiB/s.
AD 137 to 133
P/E 22056.
C3 4457
CE 58
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=498387
Intel X25-M G1 80GB
820.52 TiB
24631 hours
Reallocated sectors : 201 226
Available Reserved space: 41 to 40
MWI= 135 128
MD5 =OK
31.00 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498388
Intel X25-E 64GB
579.46 TiB
1812-30=1782 hours
Available Reserved space: 100 to 99
MWI= 96
MD5 =OK
91.26 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498386
Mtron Pro 7025 32GB
