Anvil, my sandisk extreme seems to be missing from the list of drives on the first page?
Can you fix?
Can you fix?
Ugh, will check whats happened when I get back home. (tonight)
edit:
Should be OK now, not sure how that could have happened.
(I do keep backups :) and that made it a quick fix)
Ok, new drive time:
I was kind of disappointed in how the first vertex 4 went ... so it is time to kill another:
This time, I'm going to change the rules.
Drive settings:
Firmware version: 1.5
Overprovisioning: 60 GiB
Static Data: 16 GiB
I am overprovisioning the drive so it stays in performance mode permanantly. I think the constant switching between performance and storage mode, as well the garbage collection the switch caused, was making the drive use excessive write cycles.
There are many new factors that may influence the way this drive goes:
a) If the drive is using NAND in an SLC type fashion, then each erase does twice the damage over normal MLC, as each erase cycle would only be wiping one bit, rather then 2
b) The drive may take a lot less damage during writes if the NAND is being used in an SLC type fashion, as each cell is only written once each pass.
c) Reading the data may be easier if each cell is only written once. Thus the drive may last longer due to less ECC being needed.
How this ends may really be up to how the NAND behaves.
Attachment 128566
That one should be interesting!
It might help on finding out what's going on "behind the scenes" on the V4.
Over-provisioning has been on my list of things to do for quite some time, to get to the interesting parts one needs 2 drives where OP is set differently. (both could be OPd)
Attachment 128568
Yes, in a roundabout way. There was an excellent summary and re-review of the 256GB V4 (w/FW 1.5) explaining how the performance/storage mode works as well as the mimic-ing of SLC on RWL but now the link just reloads the home page. :/ The new 1.5 was supposed to extend performance mode past the 50% barrier by tweaking garbage collection as well as give a little speed bump.
Tom's Hardware wrote something about this.
Link
The Recovery time white paper discusses MLC-1 briefly.
Samsung 830 256GB Day 122
(GiB) 2,995,490
(TiB) 2,925
(PiB) 2.87
(Avg) 298.77 MB/s
(B1) Wear Leveling Count: 12,978
(B6) Erase Fail Count: 9
(05) Reallocated Sectors: 36864
(POH) 2973
Intel 330 120GB
569.94TB Host writes
2.04TiB Host reads
Reallocated sectors : 05 20
Available Reserved Space : E8 100
MWI 34
[B5] 10
[B6] 10
[F1] Total LBAs Written 18675804
[F2] Total LBAs Read 66981
[F9] Total NAND Writes 411416GB // ~402TiB
POH 1381
MD5 OK
125.19MiB/s on avg (~253 hours)
Kingston SSDNow 40GB (X25-V)
1133.32TB Host writes (37136841*32)
Reallocated sectors : 05 62 // 1 up
Available Reserved Space : E8 98
POH 10116
MD5 OK
33.39MiB/s on avg (~253 hours)
Attachment 128598
Attachment 128599
edit:
I'll update the chart later today if there are any updates...
Sandisk Extreme G25 - 120gb - Day 46
Drive hours: 1103
ASU GiB written: 476,913.77 GiB (465.74 TiB)
Avg MB/s: 126.09 MB/s (26.39 hours)
MD5: OK
Host GB written (F1): 479,554 GiB (468.31 TiB)
NAND writes (E9): 357,930 GiB (349.54 TiB)
Retired Block Count (05): 4 raw
Failure count (AB, AC): 1 program, 1 erase
Raw Error Rate (01): 114 normalized
Media Wearout Indicator (E7): 10 normalized
Wear Range Delta (B1): 3 raw
Reported Uncorrectable Errors (BB): 0 raw
Vertex 4 - 50% OP - 128gb - Day 1
Drive hours: 31
ASU GiB written: 23,158.21 GiB (22.62 TiB)
Avg MB/s: 248.61 MB/s (26.28 hours)
MD5: OK
Host GB written (E8): 24,088.93 GiB (23.52 TiB, 50518137835 raw)
Raw Read Error Rate (01): 6 raw
Reallocated Block Count (05): 0 raw
Remaining Life (E9): 94 normalised
The second vertex 4 is going along quite a lot faster then the first one :)
That is impressive Canthearu... I wonder how long it can keep that up?
Here are todays update:
m4
1252.2432 TiB
5224 hours
Avg speed 74.47 MiB/s.
AD 158 to 150
P/E 21540.
C3 4457
CE 58
MD5 OK.
Reallocated sectors : 00
http://www.diskusjon.no/index.php?ap...tach_id=497955
Intel X25-M G1 80GB
807.84 TiB
24511 hours
Reallocated sectors : 73 to 116
Available Reserved space: 49 to 46
MWI= 184 to 169
MD5 =OK
31.39 Mi/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=497956
Intel X25-E 64GB
541.83 TiB
1692-30) 1662 hours
Available Reserved space: 100
MWI= 96
MD5 =OK
91.10 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=497954
Samsung 830 256GB Day 123
(GiB) 3,020,675
(TiB) 2,949
(PiB) 2.90
(Avg) 298.62 MB/s
(B1) Wear Leveling Count: 3,086
(POH) 2997
We're closing in on 3PiB now. 48 more hours to 3000 TiB and another three days to 3PiB.
m4
1258.2423 TiB
5248 hours
Avg speed 74.41 MiB/s.
AD 150 to 147
P/E 21642.
C3 4457
CE 58
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=498024
Intel X25-M G1 80GB
810.42 TiB
24535 hours
Reallocated sectors : 116 to 134
Available Reserved space: 46 to 45
MWI= 169
MD5 =OK
31.47 Mi/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498023
Intel X25-E 64GB
549.24 TiB
1716-30=1686 hours
MWI= 96
MD5 =OK
91.15 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498025
PLDS = Philips Liteon Digital Solutions
http://www.pldsnet.com/
Interesting that Plextor are advertised at that site too.
I doesn't know of any relation between Plextor and PLDS.
Samsung 830 256GB Day 124
(GiB) 3,046,610
(TiB) 2,975
(PiB) 2.92
(Avg) 299.14 MB/s
(B1) Wear Leveling Count: 13,198
(POH) 3021
Intel 330 120GB
589.82TB Host writes
2.09TiB Host reads
Reallocated sectors : 05 22 +2
MWI 31
[B5] 11
[B6] 11
[F1] Total LBAs Written 19327088
[F2] Total LBAs Read 68626
[F9] Total NAND Writes 425764GB // ~416TiB
POH 1427
MD5 OK
125.20MiB/s on avg (~299 hours)
1138.59TB Host writes (37309611*32)
Reallocated sectors : 05 65 // +3
POH 10162
MD5 OK
33.35MiB/s on avg (~299 hours)
Attachment 128668
Hmmm, I seem to be getting some performance degredation ... something triggered the drive to shift to storage mode rather then performance mode. The attached picture shows how each run starts fast at about 400meg per sec, then drops to around 200meg per sec.
Will secure erase and see if that fixes it!
Attachment 128682
