Did you check if your firmware on the dvd drive is up2date?
some drives screw up on some type of discs when firmware is outdated.
That's funny, because I can't get EZFlash to find my USB drive no matter how I set it up. I have used Asusupdate with no problems so far, except that after updating to 0902 and then 0903 and now 0907 AISuite doesn't run (which I don't really care about, but just curious)
I doubt that. Tweak windows = 10% gain? :rolleyes:
I'm guessing you are using a 333 strap, what divider are you on? I can't check for myself, won't boot at 333 :clap: I'm not sure about the math either. so just tell me! :eek:
from the looks of it, i'm running tighter ram, but the divider comes into play i suppose.
I'm not calling you a liar, not at all. I simply want to figure out were i could be losing 10%..... :( Are you sure you ran that score with your sig's rig?
I got tired of making DVD-R coasters so I tried 3 times to burn to DVD-R/W at 4x. This succeeded all three times. Is it possible the ISO image is bad?
Ok more results on the dividers.....I found that the 400 strap is stable for me :D
DDR2-1128 5-5-5-15 42
http://www.xtremesystems.org/forums/...1&d=1199334437
Yea I'll check it out....still going for max frequency ATM. TImings doesn't really do much for Intel bandwidth.....latency goes down some as you said.
Here is a bit of stability.....normally when it goes this far without errors then it will.....go.....all....the......way! :rofl:
http://aycu17.webshots.com/image/368...2060169_rs.jpg
Well I installed the nozzle when I first installed the block, so I had no standard for comparison :p
I use HCI Memtest to test the memory only....it will kick out an error faster than OCCT for memory only. I've already stability tested the hell out of my CPU at 3.8......plus I was browsing the internet and listening to music so I needed some CPU power. It says %100 in task manager, but it will allow other programs to take over around %5 CPU usage.....and I reserver around 15Mb or so of memory for my use.
CoreTemp 0.96 is out. I noticed some differences in readings over 0.95. You can get it from here.
Hi,
my Temperatures of Southbridge and Northbridge are a bit hi, i think.
Q6600/G0@3.4GHz@1.39_vC@1.47_NB@1.05_SB@428x8
Power/Idle Temp
NB: 65/54°C
SB: 54/50°C
is that ok or to hot? im using SE variant without watercooling, but i blow with 2x 60mm Fan's to the Headsink.
Does anyone know, how are the thermal specifikation from intel for north-/southbridge?
Just orderd a lapping kit myself, hope it will drop temps 5 degrees or so.
I made a few changes to my water loop, setup a push pull and that made a nice 3-5 degree drop in temps, I also added a Corsair ram cooler and I must say what a huge piece of :banana::banana::banana::banana: , you would think from Corsair it would be better quality. It's comming out today.
I'm hoping we get a 1xxx bios soon.
I've been checking the FTP alot.
