Not such a kick in the nuts after all then. :)
It's very strange, an address or an other is not very important,
seeing that it's the reel address of MCHBAR.
Perhaps asus use an address for read and write, and an other address for read only...
Since 915 chipsets, MCHBAR address is practically always FED14000,
I just check on differents dump of P35, it's the same for Gigabyte motherBoard,
but different for Asus (3FFB0000 or 7FFB0000).
Try to read at Address FED14000 with pmem on a asus motherboard, it will be interesting...
Edit: In case it MCHBAR was locked on Asus MB:
if((Chipsets==iP35)&&(MBString=="ASUSTeK Computer INC.")) Write->Enabled=False;
like that no cheat ;)
Got it working on Asus too ;)
Weird stuff I must say :D
Reading the same address that Gigabyte used resulted only null data, so it is not the same address.
The MCHBAR baseaddress at 0x48 bus 0 / device 0 / function 0 had to be
re-written. The original address seem to block the write attemps.
FELIX will get the final data soon.
Thanks for your time and effort guys....... :) :up:
IF sometime FELIX decide to accept donations for his lovely work, I'll be glad to donate via PayPal..... ;) :)
Not easy to do. :confused:
When you say "null data" it's 0x0000 or 0xFFFF?
You can't write a new address in this register,just write 1 at bit 0 for unlock mchbar.
I hope get it tomorrow, official release for P35 is the 4 june :)
Very thank for this suggestion hipro5, ;)
but I don't want any donation by XtremeSystems guys, simply cause
a lot of you help me to develop/debug this soft,
and surely memset don't be the same if you are not here.
Also I think some guys like you or The Stilt and others
pass a lot of time for help.It's my contribution.
On the other hand, I will probably sponsored soon :)
FELIX, email sent.
It is up to you now :D
Now itīs whiskey time :slobber:
Keep up the good work Felix :up: Saving people from buying things they don't really want is a community service :D I feel compelled to remind folks that there is this thing called a bios and you can actually make changes there that will effect your computers performance :ROTF: :eek: :rofl:
Keep up the good work dude for the hardest of the hard core :up:
it would be nice if companies did in fact have ALL RAM timings in the bios so that we don't have to resort to this software (well i would still use it for on-the-fly tests)
Dream on :) Though if they provided everything it would leave little for guys like Felix to figure out for the rest of us common folk. I'm always amazed at the level of knowledge that floats around this place. They make it easy for us mortals to plug in numbers and feel like we actually did something on our own :p:
I have to say kudos and thanks for the great job, to both of you and everyone else who assisted.
(I can't wait to start using memset again in my P5K :( )
Thanks to Felix, The Stilt and everybody.......my Gigabyte DQ6 is ready to test new version of memset :)
when i close memset 3.2 all timing readings are wiped out at least with xp64.
could you guys help ?
I know you will find a way Felix. :)
Not again, coming soon...
Just installed windows 2003 X64 and memset 3.2 doesn't work.
I found a fix:
install TVicPort 4.0
http://stuffmate.com/download/tvicport/
reboot
and i started memset 3.2 (zip version) it works
voila :D
