Originally Posted by Boble76
You need to save your 3D-voltage profiles. Otherwise the program will use the stock voltages. ( Is this your problem?)
If the problem is.. you can't hold your voltage-settings: (??)
1. (just for an example) Move the vGPU slider upper - where you want: 1.35V @ 1.45V--> apply that
2. Move the core slider upper 500 @ 700Mhz
3. Move the memory slider upper 600 @ 700, ---> set these settings--> make NEW profile --> (700/700) Save it, and LOAD.
Then go back into voltage settings, SAVE the voltage-profile to 700/700, and load it.
Hope it works and doesn't freeze when you test next time. :confused:
