On one of my xeon setups I have D20L#4 will not upload over 1100 cands. Have tried manual upload several times. All others uploaded. Any fixes for this?
Try and UL the resultsqueue.dat file from another agent... that works for me sometimes when an agent refuses to UL pointage.Quote:
Originally Posted by Hardass
I can't register..is the server down??
I just check and EVERYTHING seems to be up and running... you would register a D2OL account here. http://app.d2ol.com/memberServices/createMember.jspQuote:
Originally Posted by computerman0416
I think he means when the software asks for your e-mail address to register. I am pretty sure at this point that you don't have a node number. So, unless you have a node.prp laying around on another machine, you're kinda humped. I'm having that problem too. I can't even ping configure.d2ol.com...it get the IP from DNS, but then it just times out. I'll re-try tomorrow.
looks like this?
http://xs61.xs.to/pics/05525/errord20.JPG.xs.jpg
Yep, i had the same problem last night. It is still down afaik.
I had a node.prp from my old install and thats what I wanted anywase.
Sorry I can't be of more help guys.
That's it Mr. Big. It's still down as of 11:53 pm EST. (As I'm typing this, coincidentally.)
Can someone please tell me what this 'whole' thing is about? ...D20L
Sorry I missed this...Quote:
Originally Posted by Muteme
This should tell you all you need to know.
http://xtremesystems-dc.com/
We are starting up a new project called Rosetta@home as we have taken #1 and we need some new people to roadkill! Check it out!
BUMP!
Ok well after about 8 hours today this A64 had only racked up 12 cands and was going extremely slow on each conf. I decided to upload the one's I did and flushed the tasks, now it's downloaded new ones it is going much faster. Anyone know the cause of the problem? as I don't want it to be stuck on slow cands while I can't check up on it. :toast:
Hey guys, Any idea how you install 2 instances on Mac OSX? I've done it on windows but if I try on OSX it just tells me that its already installed...:confused:
Thanks, Ed.
The last time I saw a Mac was about 20 years ago... sorry;)Quote:
Originally Posted by eddieate
Maybe someone else has an idea?
Posting here might be a good idea:
http://www.d2ol.com/cgi-bin/ultimatebb.cgi
Did you try installing to 2 different locations?
Hey guys, just installed D2OL on my Conroe rig, but can't get DBench to work. I did standard install (i.e., paths) for both D2OL and DBench. DBench just quits whne I hit enter. :confused: :confused:
Did you copy both 'DockWin.exe' and 'GridWin.exe' into the DBench folder before starting it?Quote:
Originally Posted by uclajd
Also, you can start it by doubleclicking DBench.exe, but you won't be able to read any error messages from DBench unless you start it from the commandline ;)
Nope, I will try that, thanks. I'll assume I have to put them back for the D2OL client to work corectly? Or should I use shortcuts? :confused:
Oh, and since I am folding on this rig too, I've set the affinity to CPU 0, and the F@H client to CPU 1. Is that bueno? :confused:
Edit: It definitely likes both cores to itself. With F@H GPU client running, 137 seconds. With F@H paused, 114.
Originally Posted by Duc
Just use a copy of those two files to put in the DBench folder, that way you don't have to put them back;)Quote:
Glad you got it working :up:
Would it be alright/sensible to run more than one program like F@H, SETI@H, D2OL, at one time? Just started folding today, and noticed that there are more similar programs.
Well folding will occupy 100% of your CPU, so running another project will lead to CPU time being fought over and reduce your efficiency.Quote:
Originally Posted by PenumbralFigure
other programs that can be run side by side with little to no effect on Folding would be DIMES,MJ12,BeWeS,WhatPulse,Project Dolphin.
as those use either bandwidth or mouse/keyboard tracking.
Cheers
~B2urB
CollegiateMafia
Hey, for a P4 with HT is running one or two D2OL installs best?
with HT on, install 2xD²OL, you will get more points that with HT off and 1 install
OK,
Im pretty interested in this project, seems pretty small and I think my collection of machines could help out quite a bit.
Been doing some reading, but keep coming to dead ends, The XS D2OL site is down, and the last time the official D2OL site was updated was almost 3 years ago? :shocked:
Anyway, not knowing anything about the project, I decided to just give it a shot and work it out on my way.
Bam.
Download both installers, the Java version has some installation error, (probably due to the Java version included with D2OL is older than my current.
Then with the other installer, I get to the last step, where it installs the uninstaller and it just stops...
There are a few weird things though.
During setup where the installation shows you how much space the app will use and how much drive space you have, My drive space capacity appears as 'Error'?
I have tryed installing in 2 different directory's, the Default, and in Program files.
Each come to the same problem >.<
How do I get this working :down:
I restarted my D2OL machine & the agent icon is no longer on the taskbar, and i cant figure out how to get it back. Dockwin is running, but i cant see whats going on. What do i do?
Edit - i think i got it sorted, i ran the 'd20L service remover' and it has restored the tray icon and its running like i wanted.
