this is even better mate grats !!!
Not bad!
3226B987
http://www.firegoon.com/images/s6nqx9r.jpg
I had the exact same batch as DUMO the 3226B939 but I can not hit 5ghz without upping the volts to 1.52. The memory has been a problem to that It wont stick to the 2400 (1200) IMC without the high voltage.
http://i212.photobucket.com/albums/c...939cropped.jpg
I have high voltage but my temps are staying in low 70s when under load. Is this ok. or should I keep on looking for that golden chip.
Welcome to XS Fezzik:up:
Pic is hard to see. Can you post slightly bigger pic?
Batch 3204B958
http://minidriven.com/BlacknBlueforI...i53570kIHS.jpg
Added some Fujipoly Extreme thermal pad around die (.5mm) for support and to help cool. It's the best performance I have had so far.
http://www.xtremesystems.org/forums/...1&d=1351239711
No IHS. Direct contact between die and DT Sniper water block.
Mounted
http://minidriven.com/BlacknBlueforI...mOUNT3570k.jpg
using a EK TRUE 115X back plate for stability.
http://minidriven.com/BlacknBlueforI...teDTSNIPER.jpg
Ambient Temps 18.6C
IBT quick and dirty standard run
5GHZ@1.37v
http://valid.canardpc.com/show_oc.php?id=2578924
http://minidriven.com/BlacknBlueforI...BTSTANDARD.jpg
Idle Temps
21C 24C 21C 18C
Maximum Temps
62C 70C 67C 62C
Edited my post and cropped the images so you can see it better
Fezzik
I think is that much vcore try to slow down!
I actually got it down to 1.44 volts. I didnt have have my LLC cranked up. I think I'm going to try a different chip. I was pretty excited cause I got the exact same batch as DUMO, but another chip we go
Got a couple 3226C840 from local Micro Center...testing now
Waiting that Dumo
Found a sweet spot for 24/7 5ghz.
Ambient Temps 24C
RAM 2133mhz CL 9-11-10-27 1T @1.5v
3570k@5ghz with 1.376v
http://valid.canardpc.com/2585171
http://minidriven.com/BlacknBlueforI...47lowv5ghz.jpg
Coud not have been possible without delidding. :)
Batch#: 3226C190 with Noctua DH-14
1.216 V
http://i50.tinypic.com/2z5tc36.jpg
Well I delidded my 3rd 3770k now. A 3226. I got it stable at 1.44 volts at 5ghz but I can only run my G.skill 2400 ram at 1800 and only 16gb instead of the 32. Any ideas on to help get the 32 going. If I have all 32 in I wont even post I get a asus MB code of 55 which means no ram installed.
Up vccio and sa...
..but don't go more that 1.30 VCCSA / VCCIO if you don't want faster degradation
Here are my voltages.
BCLK FReq 100.1
CPU VOLTS 1.45
DDR Volts 1.665
VCCSA =1.2
VCCIO 1.225
PLL 1.85
PCH 1.20625
VTTDDR 0.85625
2nd VICCIO 1.2250
well i increassed vccsa and IO to 1.3 and still no go. Not worried about speed as long as at 1600 but would like to use all 32 gigs. Any other suggestions?
