yeah i tried for hours with the staples and no go, i will update tonight with the custom de pinner.
Or buy one.
Or buy one.
Does anyone know where I can get the white triple threaded sleeving besides the german website?
I plan on buying the murder mod black set, but the only place I can find the white is the german (i think its german) milliondollar pc site.
final note... I would like a website/company that ships from america.
thanks,
Phil
I'm not sure if the MDPC white sleeving is available in the US yet, but you can try sending a PM to BlueAqua - he's handling the US shipments for murderMod.
OK ... I've spent most of the day playing with my sleeving technique and learned a lot. While it's still fresh on my mind, I thought I'd share it here (warning ... lots of pics).
I successfully completed sleeving of a Corsair HX1000 W PSU - not perfect but passable. Now doing a Torture Rack build (Silverstone DA750 PSU) where the sleeving will be very visible. My first practice run on the PCI-E cable:
http://shazza53.smugmug.com/photos/5...89_hguHJ-L.jpg
It looks okay in the pic, but closer examination shows a not so good fit with the heatshrink and the PCI-E connector:
http://shazza53.smugmug.com/photos/5...85_hLhTg-L.jpg
So, I tried four different placements of the heatshrink, and thought I'd found the answer:
http://shazza53.smugmug.com/photos/5...76_BdeMs-L.jpg
The top example seemed to fit nicely into the connector, with no wire showing:
http://shazza53.smugmug.com/photos/5...25_hjKgA-L.jpg
But, on close inspection, it looked like it wouldn't take much for the yellow/black wires to poke out of the bottom of the connector:
http://shazza53.smugmug.com/photos/5...24_AvR6s-L.jpg
Dualbrain visited my worklog, and gave me a hint. He said to place the heat shrink further up on the pin. I doubted the wisdom of this, because I thought I would then have problems getting the heatshrink-covered wire all the way into the connector. But, trusting he knew what he was talking about, I tried again:
A little hard to see in this pic, but on the left most wire I placed the heatshrink all the way up the pin - to just below where the little tabs come out to hold it in the connector. It didn't work, wouldn't fit into the connector.
http://shazza53.smugmug.com/photos/5...63_jVygv-L.jpg
So, still figuring he knew what he was talking about, I tried again. This time, I placed the heatshrink lower, just below where a small piece of metal sticks out from the crimped wire - see middle wire in the pic above. It worked fabulously.
The third wire (bottom) is the same as the middle wire, but with the connector added. A peek into the bottom of the connector shows it fitting all the way in, and the pin is snug:
http://shazza53.smugmug.com/photos/5...57_FCwsV-L.jpg
http://shazza53.smugmug.com/photos/5...13_5kz6t-L.jpg
Now I'm quite happy, but it gets better. Liderc comes along and makes a suggestion to make sure the sleeving is placed very near the entrance to the connector - makes it easier to keep everything uniform. So, I had to give that a try:
http://shazza53.smugmug.com/photos/5...75_4SGzY-L.jpg
http://shazza53.smugmug.com/photos/5...62_3ZLvF-L.jpg
Thank you to both dualbrain and Liderc! You can see my heatshrink still isn't perfect in the last pic - still have to improve measuring and cutting even heatshrink pieces.
And, I'd also like to thank Dangals for starting this excellent thread. And, of course, thanks to BlueAqua for providing the blue MDPC-X sleeving and heatshrink.
A couple other notes ... I used staples to de-pin my first PSU, because I quickly broke the tool you can buy. Now, I'm using the tool and not having much of a problem. It takes just a tic to remove the pins. Secret is to work at a table, make sure the tool prongs are on the outside of the pin, and pull straight out.
I know this is probably repeat stuff for many of you, but some of this eluded me, even after having studied this thread and numerous other resources!
^^ that looks absolutly super.
I am trying to get some sleeving done here, but unlike you guys I plan to sleave the entire bunch together. My PSU is already sleeved and I just wanted to change it from black to chrome. SO do you guys have any ideas on where I can get chrome sleeves which are expandable and would go over the pins. I plan to sleeve both the PCIE, 24 pin, 4/8 pin and the sata connectors. Thanks.
thanks for the input Shazza - your work and pics are amazing and I am glad you were able to get something out of my guide!
Keep up the good work and I expect some pics of your torture rack build in here once you are finished :up:
@mav2000 - not sure about chrome sleeving - the only chrome version I am aware of is mylar sleeving however it is not a very thick weave and will show through cables the moment it is stretched even a fraction.
If anyone else has some input on this it would be appreciated :yepp:
@shazza - awesome job!! That mdpc stuff keeps getting better and better (now if they could just get a english flag on the website so I can order from zé german side. . .) everytime I see it.
@mav2000 - I bought mine from ppc's - and to be honest I wouldn't use it again. I think it's the standard stuff that everyone has (seen it on cableorganizer.com for example). it comes in only 3 sizes and if you want to individually sleeve your wires it's just too big. My only solution was to do 2 wires at a time, and even then I wasn't really happy with the final result. Depending on the bend of the wires, it's possible to see some wires sticking through. On top of that, the heatshrink didn't really like the mylar either, I had to redo several wires. I didn't use glue shrink, so maybe that would be better.
Anyway - here's a quick look
http://i256.photobucket.com/albums/h.../logans086.jpg
if you want some more pics check my siggy. . .
just arrived...
http://www.abload.de/img/a064351lr.jpg
this is realy amazing! i like this mods, thanks for recipe :up:
shazza, do you use hot scissors to cut the sleeving?
She uses her hot-fingernails :D
aka_GK: Just a good scissor and afterwards a little bit of "drive-by-melting" with a lighter and you are better than good to go.
so much sleeving this week and at the end you don´t see verry much of it. :D
http://www.abload.de/img/a0750bmhg.jpg
http://www.abload.de/thumb/a0694q4gi.jpg http://www.abload.de/thumb/a0695l3c9.jpg http://www.abload.de/thumb/a068971r6.jpg http://www.abload.de/thumb/a0686g8fl.jpg
http://www.abload.de/thumb/a0685i66t.jpg http://www.abload.de/thumb/a0678cu15.jpg http://www.abload.de/thumb/a0674tikt.jpg http://www.abload.de/thumb/a0667eycy.jpg
That's what it's all about. Perfection in corners that you can't usually see, but you know that you could look into them. :)
This thread has been awesome sleeved wires are so pretty lol :D I cant wait till I get some of my stuff in so I can start sleeving :rolleyes:
Hi guys I have an Ultra 1000w psu it's modular of course but I was wondering about the 24 pin atx motherboard cable. I am going to sleeve my system right up as described in this killer guide.
Should I build another 24 pin male to male cable (if so any pointers) or do you know where I can find a male to male 24 pin ATX pre-built (ideally black).
I am building a tiny little Danger den Water Box system and the psu is right next to the motherboard so the cable management will only be 4 inches and I don't want to carve up the original atx any ideas?
I just hoping I could keep the original cables just that, original.
btw I am in Canada if that helps. It almost never does.
Ha very true it would be bad but ROTF with one would be worse. The 24 pin extension would not do me any good because I have a modular psu it must be male on both ends. So I told Richard at Ultra I would sing his praises or more specifically Ultra's. I sent them an email and explained my situation and they offered to send me an 24 pin atx the 8 pin esp and a sata cable. I was very im pressed with the customer service and told them so. I will let you know if the cables do arrive at my door. Either way I am very happy with my Ultra SLI x3 1000w power supply.
I was wondering if anyone knows where i might get some of that super high quality red and white sleeving ? I am doing a Danger Den water box acrylic project with a Canadian theme like the flag with red and white sleeving and some white powder coating work. Please let me know I am not having any luck finding the good stuff featured in this thread. Thanks
That is beautiful sleeving, you were posting yours while at the same time I was asking if anyone new where to find red sleeving that is weird. I wish the mdpc stuff was available in Canada. Nice work by the way.Quote:
its mdpc-x.com sleeve :)
Hi titus1972 - I was going to suggest you contact Ultra about getting a spare cable - sounds like you've done that and are set.
I'm in a similar predicament to you ... with the DD Torture Rack and a 100% modular PSU. I bit the bullet and went ahead and cut my ATX cable to the length I wanted, crimped new connectors and so on. Here's a pick of Work in Progress:
http://shazza53.smugmug.com/photos/5...94_HFCaE-L.jpg
Still need to take pics of the final product, but I probably cut mine a little too short. Make sure you leave enough play in there to arrange the uni-sleeved cables nicely ;)
nice work shazza :)
What's name of that tool with blue handles? I guess it's for placing pins onto the cable?
I'm not sure I can find it here in my local stores, is it available in shops like ppc or frozen?
sorry for too much questions :D
No problem, aka_GK. Yep, it's a crimping tool - available at the stores you mentioned, or probably any local store that sells electical wiring and supplies.
Hej Shazz, I'm not getting that ATZ cable. That looks like an extension right? 'Cause otherwise the other end would be soldered to the PCB board, and not needing . . . waita minute. Doh! I get it now. .
I just LOL'ed myself to spare you all from doing that. . .
Who makes your sleeving (at least an honest question)?
