Come on man. All your friends are doing it.Quote:
Originally Posted by PanteraGSTK
You know you want to.
I know, I know...but if I blow the dumb thing up I don't want to be out my $140. But if you wanna play, you gotta pay...I might do it tonight if I have time. Any other less drastic suggestions?Quote:
Originally Posted by nosleep
Damn.... Any fix for this?Quote:
Originally Posted by zeeke
Are they all the same?
Core2s are nice cpu's, but the boards are so much crap, i've been further to exchange this for AMD again.
Hi guys
my friend have a Asus P5N-E sli and the link width is always x8 (with 7600GS and 8800GTS) ,
http://img182.imageshack.us/img182/6308/x8jh8.jpg
anyone with same problem???
regards
make sure the SLI card ont the motherboard is set correctly.
Originally Posted by lowfat
its a single VGA , and its on the first pci-e slot (blue )
regards
Yes, but if the SLI card on the motherboard is set to SLI it will make both slots 8X each. If it is set to single card then one will be 16X and the other will be 2X. Just make sure the SLI is in the right direction.
The SLi card will either set one slot to a full 16x and set the other slot to 2x or share the slots with 8x each.Quote:
Originally Posted by mascaras
Try your card in the other slot, if it works in that one as well then you need to flip the sli card.
Or an even simpler way would be to see what the sli card says since its got pretty simple instructions on it.
This board would be great except for the horrible vdroop. My voltage goes from 1.5v idle to 1.44-1.42v load. That is ridiculous. I'm considering sending this thing back. Or do a vdroop mod. The mod better work though.Quote:
Originally Posted by Eversor
I'm now up and running with my new setup after having some serious trouble. I still have one big problem. I can't run two sticks of ram. Currently i'm running 1x1gb Super Talent pc6400c4 in the black slot to the right. That's the only slot I'm able to use. If I move the stick to any other I won't get a video signal.
Any suggestions of what I can do to solve this?
RMA the board. :(
may you post a link for the vdrop mod on this mobo please ? :toast:Quote:
Click right hereQuote:
"may you post a link for the vdrop mod on this mobo please ? "
thanks a lot ! :woot:Quote:
i'll try the pencil mod today
Please post your results so I can decide if it is worth it. Thanks.
Read the mod-thread, theres plenty of results in thereQuote:
i just made it and it really works ! it's really easy with a pencil 2HB ;)
before on D-805 ( soon changed for a E6600 ) with 1.5v in bios :
1.46v idle in windows and 1.34v load ! ( 0,12v vdroop :( )
now after pencil mod always 1.5v in bios :
1.52v idle (the mod seems to increase vcore) in windows and 1.52V load ( 0 vdroop ! )
Can anybody tell me why ntune doesn't work on this board? I sure wish I could use TAT again...Or clockgen or anything. I need to do the droop mod today and see what my DMM tells me.
use the bios and speedfan
and what do those apps have to do with what your DMM tells you, you dont use those to read your dmm
just trust your DMM
You're missing the point. I just want a windows OC app. I want to know how the voltages speedfan, ntune whatever relates to actual voltage.Quote:
Originally Posted by Lestat
The main question I had was why doesn't ntune work on my motherboard?
TAT won't work too, it's only for intel chipset. You can use Coretemp ;)
i can't tell you for ntune i don't use it ...
There is a beta of clockgen that does work on this mobo, it used to be downloadable from here
www.cpuid.com/beta/clockgen.zip
The link doesnt work atm though, I have no idea why
it would be necessary to know which PLL the P5N-E SLI uses
Maybe it's no longer in beta? I'll check aroundQuote:
*EDIT*
Appears to be out of beta,
Click right here
Seeing as everyone else was saying about vdroop, i'll contribute.
My e6300 is at 2GHz (low!) currently, vcore is set to 1.25v in the BIOS.
In windows at idle it reads 1.232v, and at load the lowest i've seen it was at 1.200v.
