Read what I quoted from samcin. He said that the F4e BIOS killed his mobo. I guess I was wondering if this was a common issue or not, it has nothing to do with who prefers which BIOS.Quote:
READ THE THREAD. That happened becuase people used a DS6 or DS4 bios on their DS3
I believe DS3 has problems running 1:1 above 505 or so, at least old school D9 chips.
Tested with ram multi, goes to 530 screenshot
Tested lower cpu multi, goes to 520 1:1 screenshot
Max multi 500 32M stable 4-3-2, 505 can't even run 1M any timings
F4 bios
my 6400HZ does 495 4/4/4 with only 2.1v ( 32M ) but nothing stable @ 500 ( even with 5/5/5 or increasing vdimm ) so i have a fsb wall ram :p:Quote:
Originally Posted by kiwi
but i use multi because i have E6600 so X2.5 , X3.33 , X4 for the ram , same problem ...
yeah 2.2v 502.50 32M fine.......anything after that bombsQuote:
i even managed ONCE to do 8M 526MHz 2.3v 4-4-4-12 but can't repeat it for the life of me :slapass:
Im having a problem with gigabyte ds3, whenever i change a setting in the bios, it wont boot, it will just say. "scanning bios image in hard drive"
any idea what to do?
which bios ver
Seems to be a case of corrupted bios as a result of flashing. Try doing a recovery and/or resetting of bios? In page 15 of this thread, a guy also had a similar problem. Apparently, he got a replacement board.Quote:
Originally Posted by ZX7891
Well, i'm still trying to get mine to work at all. (spec's in sig) Gotta be my XMS2 ram @2.1v it's asking too much of the crappy 1.8v stock default.
I'm gonna go out today and get some cheap crappy ddr2 to try and get into bios so I can flash it!
18.08.06
GA-965P-DQ6 - BetaBIOS Version F4a
GA-965P-DS4 - BetaBIOS Version F4a
Wichtig !
Nach erfolgreichen Update, einmal das Netzteil ganz ausschalten !!!
(translate)
Importantly!
After successful updates, once switch the power pack off completely!!!
1. Fix QST und IDE Devices
DS4
http://www.jzelectronic.de/jz2/Download2/965pds4f4a.exe
DQ6
http://www.jzelectronic.de/jz2/Download2/965pdq6f4a.exe
Originally Posted by soki
Does this fix anything else?
MEl
Is this newer than the final F4? F4A .. F4C .. F4E .. does Gigabyte go from X--> A? :)Quote:
Gigabyte uses letters for betas, so the final version of the bios uses the same number but without the letter, so: F4a (Beta) -> F4b (Beta) -> F4c (Beta) -> F4 (Final).
Originally Posted by JohnnySK
I don't think there is a Final F4, F4c, or F4e for the DQ6 or the DS4.
anyone tried the F4a for the DS4 yet?
I tried it, nothing better than F3 final, so Iam back to F3.Quote:
Originally Posted by LordShadow
when updating bios using @bios from windows, do I have to Check "Clear DMI DATA Pool" and "Clear PnP DATA Pool"
The F4 bios rocks! Ive just put my new system together (Intel n00b) ....Ds3, 6300 DUO, 2Gb of XMS2 6400 c5 ram & a X1900XT into a HTPC case(silverstone LC14m) all stock volts & im at 450x7 1:1 memory :toast: :woot:
running prime now for hour and its stable so far!
Stock volts as in you set it manually to 1.325? because "normal" automatically raises vcore to adjust to your OC..Quote:
Originally Posted by samcim
http://img241.imageshack.us/img241/8418/samcimgv5.jpg
cant remember if bios is manual but this is it, dunno if its over-volting
12v rail & 3.3v rail are really good
yep , its overvolting when in bios VCORE>>NORMAL .
actualy you are with 1.39v/1.40v , if you dont want overvolting you have to set vcore manually
BTW: CPU_Z 1.36 already released , use it ;)
Originally Posted by Lestat
good news , all procedure was fast ( 3 days) , they already send me a new DS3 that arrive tomorow :D
and like i said and expect they told me that my other DS3 are dead ( corrupt bios) ;)
regards
mascaras: youre right mate, just changed it to 1.32 & failed prime in 0.0001 seconds :) (cpu was undervolting to 1.29 ) so ive changed it to 1.312 as it says in CPU-Z (1.3250 in bios) priming ok for now (10 mins) Oh I also had to give it 0.1 MCH to solve a booting issue (would only boot up from a button push not a restart.
anyone more tried the F4a for the DS4?!
i will receive my new DS3 from RMA tomorow and for what i read till now the best bios is F3 or F4 FINAL right???
regards
A ver se desta vez nao matas essa DS3 :D ;)Quote:
Originally Posted by mascaras
Abraço
