ok guys, there are still some things I would like to know to make this LCD Guide even better
Right now Im trying to decide between the Dell 2005fpw and the Dell 2405fpw
Ive never bought a LCD, so this would be my first time.
Would be of great help if someone who has both the 2005fpw and 2405fpw could compare the following: (and being 100% honest about it)
2005fpw vs 2405fpw
* Check for uneven backlighting, but this shouldnt be visible at all on a 2405fpw
* Compare motion blur and ghosting between both monitors using this link: *Click Here*
* Test fast paced FPS games like UT2k4, and compare motion blur and ghosting between both monitors
* Compare color quality, bright, and dark levels
* If you have a SLi solution, try running it and describe what happens
Note:
-Ghosting is when a image is duplicated with a ghost like trail
-Motion blur is when you see a blurry image in fast motion, but no trails are left behind
Please be acurate with your point of view. There is a lot of "biasing" about these monitors, since most of the users Ive seen with both are not compleately honest or dont define in great detail how it peforms in fast motion pictures.
If you have another monitor thats mentioned on the list, and would like to help in benching it, THG has a guide to help you benchmark your monitor:
http://graphics.tomshardware.com/dis...923/index.html
Depending on your acuracy, we could edit the summaries on each LCD with the less "bias" possible
Thanks for your time
Turok
