With this bios WWM said he could finally push his Gskill FF TCCD 440 chips really hard. So take that as you may. :DQuote:
I dont think my 2gb ram will clock anywhere near that good..Quote:
Originally Posted by TheMeatFrog
Hehe me either but it may help a little :D
I'm suprised I can even clock this winchester, what with its :banana: :banana: :banana: :banana: mem controller that wouldnt do above 250 with 1gb
After few tries of diff things, I came to conclusion 4 512mb is better way to go for 2gb with planning to get some decent oc (mhz wise) as well as advantage of bank interleavingQuote:
This is a MUST have for Toledo. 6/18 was horrible, this has fixed those problems.
which version did he use? -1, -2 or -3?Quote:
thanks very much :)
can you pass me his profile or MSN, to I contact him?
thanks
don't complain, my winchester can't do more than early 230's on the controller. Boo!Quote:
623-2 >>> 618-2 here.
try it.
How accurate is the cpu temp readings for sub zero in this bios??
OMFG !!! I have Cold bug issue again with Bios 618 and 623 , after 1 week ran fine , now it happens :(
My lan doesn't work in latest bios! WTF, :banana::banana::banana::banana:ing DFI....
EDIT: at least gigabit marvell lan still works :D
My onboard sound didn´t work with 623-3.Quote:
Originally Posted by QuikSilver
So I tried to flash back to 510 that I used before -> board doesn´t post anymore. :rolleyes:
Flox
My sound works fine with 623-3. I used a diamond flash image too (i hate flashing bios :p: )Quote:
Originally Posted by Flox
Diamond flash image is just a problem, when you have no floppy... ;)Quote:
Greetz, Flox
This bios is horrible. Can't run above 275FSB with my dual core 4400. When I initially plugged the cpu in (before dual cores were recognized), I could easily run 28X 3140. We need a new bios bad. :mad:
Got my new Ultra-D yesterday.Quote:
Originally Posted by Signal0101
Now there´s a coating of epoxy or something like that on the SLI-mod-bridge! :rolleyes:
So my PC is up and running again...on 510-1 as perfectly as before! Looks like a got a BIOS-corruption with the old one.
Any ideas? Hotflashing is not my thing, have no experience with these things.
Greetz, Flox
He used -1, here is the link were you can read about his FFsQuote:
Originally Posted by higherøx
http://www.xtremesystems.org/forums/...ad.php?t=66797
I am running a venice 3200, with a ultra D.
I flashed to the 2 bios, if I remember right...
I get the 233 option, but nothing else.
however, that 233 option wont work for me.
all that happens is my computer will never boot if I try it.
also, directly after flashing, I thought my bios was dead.
so I did the Insert-reset trick, and luckily it worked.
all is fine.
but if you try and this happens to you, just remember the insert trick.
Originally Posted by Kunaak
I promise I'll remember the insert-reset trick, once you've told me what it is :)
Thank you :toast:Quote:
Is this the insert-reset trick?
http://www.xtremesystems.org/forums/...ad.php?t=67540
Post 1, WWM :
if you fail to boot after bios flash , try to clear cmos or press/hold the insert key and press reset button to reset the system ... The system bios will automatically hide the non-functionable ddr divider/multilier depend on the cpu clock multiplier selected
This works well for my system, but I have a feeling that -3 isn't great for my Ballistix as only the orange slots work (no post at all with yellow, even in single channel).
Also, I think 260 3-3-3-8 isn't the peak for this RAM, it doesn't even get warm.
Anyone got any input what I should use with my Ballistix?
Hey,
I am just about to flash, I have never started the system before, but can I use this method to flash?
What I am essentially asking, is how do I flash when I know it won't post because it doesn't have a BIOS anything like new (the first PCB revision BIOS, whichever that is).Quote:
Originally Posted by From DFI Forum's
Does the quoted method work fine??
Yan
Which version would be for me with my TCCD? I can't seem to get the right ones...and would it help me out alot? I can't seem to get any overclock besides Stock clocks stable..
