Some kudos and suggestions
The fact that reps from places like Gskill, OCZ, ATI, etc. 'Live' here @ these forums and work so extensively w/ all of us is one of the main reasons that this is my favorite set of forums to visit (And you don't even have to be part of a company to be xtremely helpful around here - information and help just oozes out of the html :hehe: )
Now for some 'obvious' suggestions as to what constitutes buggy memory. (Most of us know this but I am trying to be explicit for any visiting noobs). Alot of this stuff can also be used to push your memory further if it is okay. :)
Patience is a virtue here (and no I don't have any either but I muddle through somehow :D )
1. Sticks should be tested initially at 'normal' speeds and settings (NOT AUTO, put them in!) and voltages (Same as settings).
Need baseline to know if they are getting better :D.
Run the full memtest, not just 5 (once for starters, just to make sure).
Unless they generate 1000s of errors, you should then 'acclimate' them to your system for 1-2 days @ low (normal) speeds + 1 step up on the volts (you can drop it back when testing later) (burnin has saved me many times)
Of course if you are the lucky recipient of damaged goods(1000s of errors @ lower speeds), stop here and check for stupids, then get tech support :bsod: :cussing:
If you have 'borderline' problems - test sticks individually
2. At rated speeds or below, if you get reproducable memtest errors (same addresses, even though maybe different tests) that follow the memory when moved to another slot - buggy memory.
3. Also different sticks usually have a 'favored' slot (drive strength = distance from CPU), Try swapping sticks to see if the # errors decrease and if some errors move w/ the stick.
4. Memory chip settings change for different speeds and I have even had to swap sticks when OCing @ the edge.
I have one stick for 0437 that is a POS(was borderline when I remove the stickers to zap local heating issues, then some bits failed altogether but no stickee - no RMA (OPB, any suggestions? :D ))
OTOH you see in my sig what I have now (and they are SOLID) Partly because of OPBs, etc settings. etc. (And I am leaving the labels on this time :D )
I have 3 3200+, the others don't get near what this one does. I also can't get much over 278 on my neo2. So remember that these speeds require matching hardware (chips and MBs) that are up to the job. We forget sometimes that not all hardware is equal (cough CBBID 05.. cough) etc and that most of this stuff is based on reference designs that are based on FSB standards of 200 Mhz .... We're just the lucky ones that look and find the good stuff (well mostly) :D
