LoL. They just took the change in transistor count and applied it to the die size...
If transistor count and specs are true, you would be looking at ~250mm2.
it is supposed to be on goflo and not TSMC, so the drop in TDP could happen. it could also be similar to the change from 45nm to 45gt when changing from the 4870 to 90 and that made a huge difference with voltage needs and leakage.
if it is spec based they can not really destroy the PR like promising better single threaded performance and overall faster but then making something that is slower per clock with the same number of threads, but they gave us some thing the same single thread at the same clock and slower when you use both threads on a module.
I have to agree that these rumors are most likely inaccurate and something fabricated to create page hits. Any early rumors have been way off about AMD lately and performance has basically under delivered since 5870 according to early rumor hype.
As for the performance of the next 8870 having gtx 680 performance. This is completely possible. However I still think these rumors are false. Not so much about being a pessimist about possible performance figures but all these rumors from AMD lately have been completely off. 6970 and 7970 History threads show this. The 6970 performance was supposed to deliver the type of performance you expect from a new node and new architecture and the 7970 was supposed to beat the gtx 580 by 60%. The reason why these leaks aren't likely true is AMD wouldn't let this information be know this early. Price and performance months out? Neither tech company has let this much information leak 5 years ago even and today, information secrecy is even more tight. AMD is one of the best at this right now. I.e keeping bulldozer underwraps and 6970 and 7970 performance until close to launch.
Showing how much performance and your target price this early is a huge mistake. This information advantage lead to the collapse of all 7xxx pricing and for the gtx 670 and gtx 680 looking better than they were.
thread should just be locked, the source is 2ch which is well known for being as reliable as reading the future out of the shape of some random dog turd found on the street.
The specs are quite realistic and very much what we can expect from AMD. AMD knows the GTX 680 is going to be the next gen GTX 760 Ti when the GK110 chip launches as the flagship GTX 780. The HD 8870 chip has identical resources as HD 7950 - Shader count (1792), 112 TMUs, 32 ROPs and other resources like 2 ACE, 2 rasterizers, 2 tesselators. The 256 bit memory controller of Pitcairn will be updated to run at 6 Ghz. The HD 8870 will be gaming focussed and perf/watt optimized like GTX 680. HD 8870 has a good chance of matching the HD 7950 at the same clocks. As we have seen in the past AMD also makes improvements to the tesselators and other performance tweaks will also be done. And with improvements in the 28nm process you can expect lower voltages compared to HD 7000 series to hit the same clocks. Other areas like reducing chip redundancy because of a more mature 28nm process would mean transistor savings. So overall a 3.4 billion transistor chip which matches a GTX 680 is quite expected.
http://www.techpowerup.com/reviews/S...apor-X/31.html
HD 7950 (1100 Mhz) matches a HD 7970 Ghz (1050) . I would expect HD 8870 (1.1 Ghz) to atleast match HD 7950 (1.1 Ghz) at 1080p and 1200p and fall behind slightly at 1440p and 1600p .
What GPGPU resources does Pitcairn have, that can be cut?
I'm referring to Tahiti here as (I would assume) that iteration of GCN would be the basis of any evolutionary changes. Many could even cascade down to encompass the lower end cores as well.
A good example of optimization would be the Compute Unit itself. As NVIDIA did with Kepler, streamlining core functionality with a focus upon gaming starts with the "building blocks" of a given architecture. I wouldn't presume to say how AMD can cut items since I'm not an engineer but any large scale move towards prioritizing certain functions starts here.
The Tahiti refresh will most certainly not be cut down regarding GPGPU. I though we're discussing Oland?
Because there is always a trade-off of some sort. AMD needs Tahitis strong GPGPU part to stand their ground against Tesla. Optimizations in general yes, but not at the cost of GPGPU efficiency (at least for Venus Pro/XT).
A 200% blown up Pitcairn as a possible solution for Venus is out of the question, imo. That is what I essentially meant. Their largest chip won't be purely about gaming, same as Tahiti. That said, Pitcairn is. So I'm unsure what is there to optimize especially.
since high end gpu sales should be focusing on gaming perf. as laptop perf for gpgpu.
cause if a game comes out that sucks on it, cause of finally making awesome use of gpgpu they just ramp up the laptop gpu's perf and call it the desktop one.
If those specs are real, it means the 28nm was incredibly bad and now is finally ok with good yelds, how else would you be able to sell a faster gpu cheaper?
higher demand due to the cheaper price, covering r&d costs over a higher number of cards instead of less.
as they proved with their last round of gpu's. when the price dropped it was an upgrade worth paying for. covering the r&d costs finally that the higher price couldn't do , due to the demand for the product.
so through the higher efficiency of longer runs of the lines. less hydro costs due to less switching products on the line, less programmer payments for the higher paid employees. less reprogramming the line switching between products. using the card that don't meet speed requires as re branding in the lower end market. loss prevention and costs of recycling the material. not forking over voluntary carbon emissions fees. less environmentally friend logo certification stickers. accepting gaming is not environmentally friendly and lowering power consumption reduces the dependence on nuclear power was proven by fukashema to be the least environmentally friendly. so just lowering power consumption proved more environmentally friendly and they don't need a logo of someones to show that. less artists making boxes, selling the cards not marketing to sell cards. moving all the stupidity costs of marketing to the re sellers who buy in bulk of 1000's of units. 1 year warranty. letting re sellers eat the costs for more in their prices. letting the guy selling cards in a oem brown box compete. moving all accessory to the re sellers to cover at their discretion. no partnerships with game developers leaving that to the re sellers. giving up on producing tech demos when games do that fine. helping game developers optimize for their code paths instead.
a new guy making the decisions.
I dont say thoses specs are real ... but you know GCN first "chips" have tapout in march April 2011. production have been start to be ramped around october 2011 ( maybe even september )..
We approach slowly the end of 2012.. the way of product 28nm have certainly evoluate since.. ( the hunt of energy lost, the capacity to put more transistor on an equivalent surface without increase much the TDP etc etc. ).
Even the yield ( and so cost/revenue for AMD or Nvidia ), the risk is now better controlled...
(Remember Nvidia Fermi, who have do a lot of progess on TDP between the 480 and 580 ( and the core is nearly exactly the same.. 90% of the tdp removed was by change some transistor size where they was too much leak )
HD8000 will sport GCN2.0, as allways during a developpement, there's a moment where you let the baby to the "engineer production " team ( the guys who take the project and decide of the final specifications ), letting down many thing the initial team will surely like got more time of include it, we shoud surely see some slight optimisation and correction of the initial GCN .
Dude I done even know why I just read your whole post but seriously what the hell do u mean man? :confused:
Anyway, the current crop of 7xxx cards show that there is certainly room for faster clock speeds as well as lower operating voltages. I feel that the next gen cards will benefit greatly from that along with process improvements (+ what Lanek said). Of course, GCN 2.0 will increase shader efficiency so while these specs might not be real, its not too far fetched to believe either
man sea islands is soooo last week
I want Pirate Islands!!! Yaaaaarggg
http://vr-zone.com/articles/amd-next...mes/17154.html
2015: Pirates of… Graphics?
Perhaps one of most interesting codenames is coming down the pipe in 2015: Pirates Islands. Yes, you've read it correctly. Bringing a tribute to legendary pirates such as the Blackbeard, Captain Hook or well, Captain Jack Sparrow, AMD's imaginative engineers are targeting the 20nm process with 14nm APUs in mind. The real work on this GPU architecture only started recently (GPUs are being designed 2-4 years in advance) and guessing what lies on cards is a bit too unpredictable. We know feature set, but performance… your guess is as good as ours.
Read more: http://vr-zone.com/articles/amd-next...#ixzz26ycbZT1D
Next-gen flagship Tenerife HD 8970:
http://www.pcper.com/news/Graphics-C...-Graphics-Card
