FlanK3r,
Using IDE mode realy does help. I could not boot over 110HT Ref, now I can!
FlanK3r,
finally I began with Llano...looks pretty nice
Attachment 120140
have fun, lookin forward to see how your rams do :)
For people getting stuck with HT ref, try using 133+ mhz. I think I've read it uses different dividers at those settings for SATA and PCI-E, so 133-134mhz might actually be more stable than say 125mhz. Not sure if it's true, but I guess it won't hurt to try :)
So...with actualy BIOS I have problem with bclk higher than 115 MHz :(. 115 MHz is stable, with 116MHz I got blackscreen. Boot with 116 Is not possible. I thought, there will be included some as dividier about 130 MHz as Giga, but doesnt seems. GPU I have at 6xx MHz, so, there will be not problem. Looks like HDD lcontroller limitation?
I have it in VGA, ok, I can try HDMI
yes, no post....But now Im at 121MHz stable (OC still in process, HDMI switch help me :) ) RAM are awesome, I got with 1.65V 2260 MHz 8-9-8-1T quick stable LINX 15 loops!
133 broked, but unstable with 28x (with lower multiplier OK)...:-/
Gogo flanker,i hit 155 on air,you can do it too :D
with which board Alex?:)
F1a75-m-pro.
I'm 24/7 stable and can loop 3dmark06 on air at 152 with The Stilt's new F1A75-M PRO bios as well, even with the ram at ~1013MHz. Vantage score is pretty close to what it is at 133 ref clock with similar memory speeds though, probably since I have to turn off bank interleaving for it to run at those clocks.
--Matt
MY CPU want not more, than 3600 MHz stable :(....
Mine either. Barely even wants 3600. I'm running 152x23 with ram at 1013@9-10-9-25-35. I get P4948 in vantage with it like that. I think mine needs +.05 on the CPU and +.125 on the NB to do that.
--Matt
Do you think it's worth the wait for the unlocked llano A8-3870k? Is there really gonna be any difference besides it being clocked at 3.0ghz? I thought the current 3850 was able to unlock already?
Hopefully it will be fresh silicon considering they have been having less than Stellar yields i want a fresh zambonied Llano :)
4.0 ghz llano would be nice with some Ddr3 2133 memory's :)
I have an A6-3500 (3c, 2.1G/2.4G, 320SP 444Mhz, 65W). It's been running fine at 3150Mhz (150*21) but I wanted to use the Turbo multipliers, is there any way? With latest BIOSTAR BIOS I can't get past 21x
Not OC related but my 3850/F1A75-M Pro stock speed with 4G 1600ram at 1.5v, a single 64G SSD and a Fusion5 Gold tuner all running off an ancient Antec 420w Neo PS pulls 60w at desktop, 90-98w watching HDTV (no matter full screen or not) and 115w playing an Indie game full screen. Come to think of it, the external M-Audio box is USB powered. Pretty light weight for a GP rig.
You need to tweak the voltage using k10 stat,i have 0.8 idling at 1000 mhz and 1.2 load at 3100 mhz.Power difference from my old ph2 955BE is HUGE,also heat....
