AMD Turbo CORE allows customers to tap into additional clock speed headroom by allowing the processor to rise up from the base clock speed up to the TDP level, automatically unlocking extra potential for the processor. Should the processor get too close to the power limit, it does automatically step back a bit to ensure that it is continuing to operate within the specified guidelines. This allows for significantly higher maximum clock speeds.
Some of the benefits of AMD Turbo CORE include:
· Up to 500MHz of additional clock speed available with all cores active. This means even with multiple cores active with full workloads, all cores can boost at the same time. For those customers that want to maximize their performance, they now have the tools to do it.
· Even higher boost states available with half of the cores active. AMD is not stating exactly how high processors can boost with AMD Turbo CORE, but obviously if there is room for up to 500MHz with all cores active, fewer active cores would obviously mean less power, and more headroom to recapture with AMD Turbo CORE. At launch you will see processors marketed with a base and a maximum frequency, base will reflect the actual clock speed on the processor and max will reflect the highest AMD Turbo CORE state.
· AMD Turbo CORE is deterministic, governed by power draw, not temperature as other competing products are. This means that even in warmer climates you’ll be able to take advantage of that extra headroom if you choose. This helps ensure a max frequency is workload dependent, making it more consistent and repeatable.
