My problems here.
http://www.xtremesystems.org/forums/...107#post310107
Antec was fine on the 3.3v and held better, but my 12v was down to 11.4.
The fortron 350 i have holds voltages better than both of these premium supplies.
My problems here.
u said it like u givin it to me for free lolQuote:
Originally posted by XtremepH
don't worry i'll get ya one when i order mines.
so when you turned the fushia pot the 5v changed as well as the 12v?Quote:
Originally posted by Jeff
Red = 3.3v adjustment
Blue = overvolt adjustment
Fushia = +5v/+12v adjustment
Green = overvolt adjustment
That's how I see it. The overvolt adjustments are for the +3.3v, +5v, and +12v rails. It's the voltage where the PS will kick off.
+3.3v max ~ 3.8v
+5.0v max ~ 5.4v
+12.0v max ~ 14.0v
Those are my findings at least. ;)
my 5v never changed the whole time i was testing the different pots.
i guess from what you are saying the blue needs to be turned up all the way.. sort of like a crossover for the fushia to operate fully. i'll test this in a few minutes.
ok i turned the blue pot all the way counter clockwise and adjusted the fushia pot and it DID alter the 5v and 12v.
Jeff's max voltages agree with mine as well.
I noticed that this PSU does not have Active PFC, I know what PFC is there to do, but does it work? As far as I can tell, that's the only drawback...and it may not even be a drawback for all I know.
Looks like an awesome PSU!!!:slobber: :slobber:
I'll probably replace my Smart Power 350w with it.:)
Like i said fortron should give Maxvla some $$$, his pics are going to sell a lot of these!!!
why is PFC important?Quote:
after a quick google search the only thing PFC does is allow you to use any input voltage 100-260 (range i saw) and it will automatically correct it. (Power Factor Correction)
bring it Fortron! :DQuote:
i could use it http://www.maxvla.com/smiley/evil.gif
Anyone seen one of these for sale cheaper than newegg?
yeah, I don't think it's that big a deal either. In fact, I heard it creates a slight buzzing noise. All of PCP&C units have it though, so it must be good.Quote:
This PSU is next on my list of upgrades
Its really quite useless unless you are hooking your PSU up to a line that changes between 220v and 110v all the time..
That little switch on the back can be handy, if you ever hook it up to a 220 line.
which is... uh.. never :wiggle:Quote:
Unless you don't live in the US......
....Quote:
right
I'm just saying it could be useful if you didn't live in the US.
Oh, I guess my understanding of PFC was incorrect. In that case...I would never need it.:)
Ahhh, this is a tempting upgrade!:slobber:
PFC - Power Factor Correction - is circuitry that makes the PSU more efficient under varying loads.
A simple example: Uncorrected industrial electric motors draw as much as 200% of the electricity needed to produce their expected output. With PFC, they can approach 95% efficiency.
A PFC-corrected PSU is more efficient and economical WRT the power drawn from the mains versus the power delivered to your system.
The main purpose for PFC is conversion efficiency - 120/220v input to the 12/5/3.3 output of the PSU. A PSU with PFC is more efficient at this (more "green") than one without.
Anyone know a store to buy it in that ships to sweden? Newegg are evil :(
http://www.dealsonic.com/fofgr.html
I get stuff from here a lot and noticed they have fortrons on my searches. $1 cheaper But shipping is $1.95 more so no then.
I've been using the bottom one's the 350 watters for cheap supplies. $19
http://www.dealsonic.com/fohiqat35atp.html
And this one for nicer rigs for customers, super quiet with the 120mm fan
http://www.dealsonic.com/fofsause35at.html
There are some reads on PFC here
x1zt: As i understood it the psu only works on the 110-115v net :(. But we can hope for a 230v version :).
my fortron 530w has a slider on the back for 115 or 230. http://www.maxvla.com/smiley/dunno.gifQuote:
Aha, ok. Then i was wrong :yawn: It's really cheap in the us too :).
100% correct.
same schematic and pots on the sparkles, of course.
There is a switch on the back like all other PS just about for 230v
