I decided to create a hybrid physX setup on my machine using my old 9800GT card as a PhysX hardware accelerator. Yes, I know that NFS Shift is reported as using the CPU for PhysX, but my testing results say otherwise, at least if you are running a Radeon card with an Nvidia card just for PhysX.
Anyway, after noticing a subjective improvement in the frame rate tanking whenever any of the visual physics effects came into play, I decided to check with FRAPS, just in case this was a placebo effect.
Well, according to FRAPS, it wasn't - the game was actually running better.
In a test I did at London, for example, I took the frame rate with vsync off when I was in the :banana::banana::banana::banana:pit at the back of the grid awaiting the race start. All the game settings were at medium, except for textures which were high. Antialiasing and anisotropic filtering were both set to 8x (box mode for antialiasing). The race was setup with 5 opponents and I of course was at the back of the grid. I also measured the lowest frame rate during the one lap race.
So here are the results:
Radeon 5870 only:
FPS at back of grid awaiting start: 91
Lowest FPS recorded: 28
Radeon 5870 plus 9800GT for PhysX processing:
FPS at back of grid awaiting start: 104
Lowest FPS recorded: 38
I repeated these tests about 10 times and the results were consistent - the above are averages, though there was little variation between averages.
Testing is the only way to see and testing is what we are doing not just talking about it,this is not aimed @ anyone.
