Seriously franklin5252, do you need to quote the whole post??
anyone verified this on a BioStar TPower i45?
I assume this would work on my Gigabyte 790FX board. Does Quad SLI work, though, e.g. two GTX 295?
No idea if quad SLI works, I haven't been able to find out if SLI works on my BioStar TPower i45.
Works of course.
Hi
is there a possibility to run Quad Sli(7950 GX2) on X58?
Have here to cards, but the newer driver(180.xxx) doesn't support this cards in quad-sli anymore. but the older driver(17x.xxx) doesn't support sli on x58:rolleyes:
hope ypu can you help me^^
Eiswolf93
Eiswolf93
Are you sure? SLI on GeForce6 series works ok.
I think so, tested on a Asus P6T Deluxe, i can't apply quad sli in the driver menu.
also in hwbot there is no score with a I7 cpu.
Anyone know if its possible or if a hack exists to do crossfire on an nvidia board?
Someone made a program that hacks the bios and adds x58 certificate to a few different bios types. Same thing as here but hard modded. MY DIGITAL LIFE
should i put SLI bridge for second card only for physX ?
