Doesn't eleet show NB & VREG temps???
Nice review...thanks :up:
Nope, only VREG.
So did you get your VREG #s from eleet for from the BIOS like the NB results?
From HWmonitor, which reads the same info as eleet.
sorry to bring up an old post but it is a good one.
Does this require a seperate loop or can i put this in the same loop as my CPU?
I'm doing one loop that has this block and CPU together. Gonna be a bit before I get it up and running, but from what I've read, should be fine.
thanks for share:up:
I also think that putting your MB in a separate loop is overkill. But some prefer it.
What I can say for sure is that it's not necessary to have your MB in a separate loop. You can do it and it might give a small temperature advantage, but it's far from necessary.
nice test! congratulations.
I have one more doubt is no difference between the block for the e759 and e760?
and where they think this EK blocks mainly with acrylic cover? any store that makes sending to the world!
