Max stable on Air? :O
WOW :eek: you're brave mAJORD!
Popping lid in such a new CPU :D
Has it died on you or you were sure it will survive this operation?
When we can expect first results from you?
BTW in Athlons 64 mem controller was in sync with CPU clock, so X2 6000+ ran at 3GHz ;)
Independent IMC clock is required for independent core clocking. Also enabled K10 to maintain same memory frequency across a range of CPU multipliers (K8 memory speed varied depending on CPU multi.). Same as in Griffin, Regor will have ability to clock cores at different speeds. I only hope AMD added option to completely shut down a core when not needed! That would be cool on a laptop!
Maybe I missed it but does this chip have unlockable cores?
thanks Lightman..
The only CPU I'm not sure if it still works is the 9850BE, due to the heating process to flow solder, I bent the package, and failed to straighten it before it cooled (it was ****** hot!) and it's stayed bent. Have to try reheat+straighten and see if it hasn't fractured any of the bumps under the die!
I'll post results tonight, as an idea though, Agena/Kuma like perf. clk/clk Looking at around..
2.5-10% on basic integer varies wildly
10-15% for gaming/3dmark, (With a 2000NB)
POV ray in the 20%+
Encoding 10-15%
and an interesting one.. SSE2 Mandrelbot bench.. ~75%
Coming tonight also, need to swap a low power vid card in, or maybe throw them in a MINIX
wow, Griffin was larger than I thought :)
Is that an official figure? My measurment may be a bit off, i'll borrow some decent verniers :)
CBJ: Re-run at 3ghz
I cannot confirm nor deny if it's official or not :) you will have to believe me :D
Based on die picture and this number I have estimated die width and length to be ~ 13.8 mm x 8.5 mm.
No, it's not that big, something got messed up here :eek:
This should be a better measurement from the photos,
assuming Socket S for Griffin (35x35mm) and Socket AM2
for Regor (40x40mm):
45nm Regor: 8.45 mm x 13.9 mm = 117 mm^2
65nm Griffin: 10.0 mm x 15.6 mm = 156 mm^2
Regards, Hans
Sounds better hans.. Still seems a good shrink considering the larger cores :)
Anyway I've updated the OP with out-of-box stock vs stock 6000+ comparisons, brisbane and windsor.
NOTE that's NOT my uARCH comparison tests.. I'm Re running them Vs Windsor at 2.8ghz to get equal RAM clocks (even multi), and at 2800NB (sync)
mAJORD great work man,you have ballz of steel :D.
The core looks sexy naked :).
I'm looking forward for your head on duel with K8 @ 2.8Ghz and synced NB for Regor at the same clock :). Keep it coming!
Any requests for added benchmarks?
I'd like to re-run tonight, so pls post here
hi QC, I did test that with cpu-z latancy tool, but forgot to post results.. it's the same as Phenom..
L1: 3 Cycles
L2 15cycles..
so slower than windsor (12 cycles)
Can you please try to run some Sandra / Everest Memory Bandwidth Test?
It should be interesting to see the difference with K8 and K10.5
Thanks !
mAJORD,
Could you please check whether kink's PhenomMsrTweaker works with Regor.
Thanks.
no worries high5, if someone else hasn't by tommorow. Still getting k8 results.
imamage, sure. am including all the benchmark suite too.
Hey mAJORD, could you give me some undervolting numbers? My 7750BE is kind of toasty :)
K8vs K10 uARCH comparison results posted!
Awaiting feedback and more benchmarks (and prepared to run new tests on both CPU's again!)
Updated OP with results, and descriptions.
will try to fit that in this w/e. i am interested also i have to say.
a no go. CPU type not supported on install :(
