My setting for 1600 I have more for 2000
CPU & Batch (3849A866)
RAM Model (Mushkin 998708 2000mhz)
Bios Ver: Quantum BIOS P06 and G25
CPU Features
PPM : Enabled
EIST : Enabled
CxE : Disabled
Execute Disable Bit : Disabled
Virtualization : Disabled
Hyper Threading : Diabled
Active Processor Cores : ALL
Memory Settings
Memory Controller Settings
IMC Configuration :Enabled
Channel Congifuration :Independent
Channel Interleaving :6
Rank Interleaving :4
Memory Timings
Extreme Memory Profile XMP : Disabled
Memory Profile Select :auto
DRAM Timing Control :Manual
tCL (CAS Latency) :6
tRCG (RAS to CAS Delay) :6
tRP (RAS Precharge) :5
tRAS (Precharge Delay) :auto
CR (Command Rate) :1T
tRFC (Refresh Cycle Time) :auto
tWR (Write Recovery Time) : auto
tWTR (Write to Read Delay) : auto
tRRD (RAS to RAS Delay) : auto
tRTP (Read to Precharge) : auto
All Voltage Settings
CPU Voltages
CPU Core Voltage :+30mV
CPU Target Core Voltage :1.26750
CPU Vdroop Compensation :Enabled
CPU VTT (UnCore) Voltage :+80
1.8 PPL Voltage Setting :1.800
CPU Clock Amplitude Ctrl :.800
Memory Voltages
DRAM Voltage :1..65
DIMM1 Vref CA (Addresses) :.500
DIMM1 Vref DQ (Data) :.500
DIMM2 Vref CA (Addresses) :.500
DIMM2 Vref DQ (Data) :.500
DIMM3 Vref CA (Addresses) :.500
DIMM3 Vref DQ (Data) :.500
Chipset Voltages
X58 IOH Core Voltage :1.10
X58 IOH VCCA 1.1V :1.108
X58 IOH VCCA 1.5V :1.506
ICH10 SB Voltage :1.506
OC Gear : Skipping this part
CPU Turbo : Always On
System Turbo : Enabled
Clock Speed Control Center
CPU Bclock (FSB) : 200
QPI Link Fast Mode :
QPI Multiplier : x18
QPI Target Speed : 3605(7.2GT/s)
CPU Core Multiplier : x18
CPU Core Target Speed :3605
CPU Uncore Multiplier : 18
CPU Uncore Target Speed : 3609
Memory Bus Multiplier : 8
Memory Bus Target Speed : 1604
CPU Clock Skew : Ops
IOH Clock Skew :Ops
HT Enabled (Not that I use it but it works)
RAM Model (Mushkin 998708 2000mhz 8-8-7-24-1T)
Bios Ver: Quantum BIOS (G25)
CPU Features
PPM : Enabled
EIST : Enabled
CxE : Disabled
Execute Disable Bit : Enabled
Hyper Threading : Enabled
Active Processor Cores : All
Current Feedback Override: Enabled (added this one for HT otherwise Multi Drops)
Memory Settings
IMC Configuration : Enabled
Memory Timings
tRFC (Refresh Cycle Time) :Auto
tWR (Write Recovery Time) : Auto
tWTR (Write to Read Delay) : Auto
tRRD (RAS to RAS Delay) : Auto
tRTP (Read to Precharge) : Auto
CPU Voltages
CPU Core Voltage : +40mV 1.27750 Cpuz reports 1.26, and jumps to 1.328v under load CPUZ-1.51, Hottest core 74C. coolant @ 32-33 C
CPU Target Core Voltage : 1.27750
CPU Vdroop Compensation : Enabled
CPU VTT (UnCore) Voltage : +200mV
1.8 PPL Voltage Setting : 1.856
CPU Clock Amplitude Ctrl : .800
Memory Voltages
DRAM Voltage :1.65
DIMM1 Vref DQ (Data) : :.500
DIMM2 Vref CA (Addresses) : :.500
DIMM2 Vref DQ (Data) : :.500
DIMM3 Vref CA (Addresses) : :.500
DIMM3 Vref DQ (Data) : :.500
Chipset Voltages
CPU Turbo : Always on
QPI Link Fast Mode : Enabled
QPI Multiplier : X18
CPU Core Multiplier : X18
CPU Core Target Speed : 3605
CPU Uncore Multiplier : X18
Memory Bus Multiplier : X8
PCI Express Bus Clock : 100
IOH Clock Skew : Ops
:up:
Oh and if I enable the AutoShut down. The readings go crazy... All voltages go to 4.06 not acutally go there but reports as such, and does not happen all the time random but only happens if I set it....
Crazy Chit...
