oooh that sound like my cup of tea :up:
I have an 80mm fan running on 18v bring air from outside onto mine, ported through a ventilation hose. It gets my a-data ddr2-800 (5,5,5,18) to ddr2-1147 with (4,5,5,18)...so yes it could be your cooling is helping a lot, aswell as the volts ofcourse.
The easiest way to determine if there is any synthetic performance increase would be to run everest/sandra/crystalmark mem bench at cas 4,5,6 and 7 with the speed kept the same.Quote:
but seriously:
how could i prove this results for 100%?
cas 4 @ 1600
cas 5 @ 1600
cas 6 @ 1600
cas 7 @ 1600
this will show the any small increases in performance. What we really need is for another user to also try this. If others can test and confirm then it's by far the easiest way to confirm it.
