dam these Phenom IIs look fun to overclock!
congrats Hazzan :)
how's the DDR2 oc'ing on the platform ?
congrats Hazzan :)
Hazan: what is max Air OC on this board? Better than ASUS M3A-T Deluxe???Try with 1.5 or 1.55V with Air :). I hope for 4GHz, cause i want new MB ASUS M3A-T deluxe or M4A-Deluxe...I dont know, what is better.
@Benny Lodewijk : thanks Boss....:D:D
@macci : Thanks and course Master :):).....I need some bios update I try with 5.5GHZ almost same performance run on 5.750 GHZ...
http://img502.imageshack.us/img502/2091/5500am4.jpg
@eva2000 : I dont haved try maximum memory with PHENOM II and this board I will try later George....:)
@FlanK3r : on air I can get 4Ghz stable on all 3D Bench....:)
http://img229.imageshack.us/img229/8717/3dmark05dk9.jpg
http://img108.imageshack.us/img108/2310/3dmark06sa2.jpg
Nice clock's Mbah Hazzan:clap:phenom is sexy
waiting PI32M @5.9-6GHz:up:
yeah come on amd guys run some 32m's if the wr 32's where 18min range before now should be closer to 12min id say :)
SoF, massman,
I see - thanks for the clarification.
Hazzan,
did you set SPi process affinity to run only on the fast cores when you ran at 5.7GHz? looking thru the screenshots it seems that in the 5.7G run you had core 0 and 1 set to that speed and the other two were at 5.5GHz. if process affinity was not set to core 0 and 1 only then that might explain why the score is close to your 5.5GHz run (all cores at 5.5GHz).
:rofl:When i see these res..... ****** Nice work:up: Hmm do you think he needs only cold? Because myne is don't goin so far at these Voltages..... At mom. i have an Asus M3A78-T. And its working not so fine:shrug:
Hazzan: thank u, il buy this board :)
