OK so after what feels like a year. I finally got to squeeze a few hours in to spend with the rig.
I drained, flushed and refilled my system and changed from red to blue. I felt the red looked more pink than anything and I wasn't happy so blue it is! also I got the sunbeam rheobus and took off the faceplate and replaced it with the brushed aluminum "blank" that came with my case per Cloxxer's suggestion. I think it looks great and WAY easy to do drill a few 1/4" holes for the LED's and a few 3/8" holes for the controllers. I also added a small switch in it as well for my UV lights that I wired together to use 1 switch. Here are some pics of it :)
Before I refilled my system I had to switch the tubes on the waterblock because the apogee GTZ has a directional flow to it and I had the input on the output barb.
The downside was that I had to move my HDD's down to the basement area of the case but even that wasn't so bad, less visible wires and Now there are 4 san ace fans across and it looks cool. Almost all the fans are San ace now and the ones that aren't....will be soon :)
I used some black poster board in a few spots to cover up and give a more finished look to anything I felt needed it. I just did it quickly and I am going to re do it with better cuts when I get a chance.
http://img100.imageshack.us/img100/8...8222197mf9.jpg
http://img100.imageshack.us/img100/1...8215318ic2.jpg
http://img518.imageshack.us/img518/5...8228815bf1.jpg
http://img100.imageshack.us/img100/3...8291972bb1.jpg
http://img505.imageshack.us/img505/3...8304274ew3.jpg
http://img524.imageshack.us/img524/7...8298119fn2.jpg
I changed the "drainport" from the red anodized to a delrin one to avoid corrosion
http://img100.imageshack.us/img100/8...8424699vy8.jpg
Here are some different angles and different parts. I have more and a youtube vid that is uploading I will add them later guys.
http://img524.imageshack.us/img524/5...8492353xk1.jpg
http://img146.imageshack.us/img146/6...8485452os9.jpg
http://img527.imageshack.us/img527/9...8449790qv5.jpg
http://img527.imageshack.us/img527/6...8443471sk0.jpg
http://img407.imageshack.us/img407/7...8436870os2.jpg
http://img146.imageshack.us/img146/9...8430628sy2.jpg
http://img146.imageshack.us/img146/1...8413968yx6.jpg
http://img100.imageshack.us/img100/4...8407397fz4.jpg
http://img527.imageshack.us/img527/6...8397728bb9.jpg
http://img505.imageshack.us/img505/3...8391477fi6.jpg
http://img100.imageshack.us/img100/7...8384139ol9.jpg
http://img402.imageshack.us/img402/9...8378351wm8.jpg
http://img100.imageshack.us/img100/6...8359229kd2.jpg
http://img409.imageshack.us/img409/6...8338999ee0.jpg
http://img505.imageshack.us/img505/7...8315567bk6.jpg
http://img524.imageshack.us/img524/6...8270095uo0.jpg
http://img529.imageshack.us/img529/7...8243385ya5.jpg
http://img505.imageshack.us/img505/6...8235652vv6.jpg
So I am going to officially upgrade this version to 1.6 :) because I am almost done with this one but I have some plans for the near future
