Looks good but different.
im getting that a lot.
Everyone says my sides have been ported for the second accelerator.
However the funny thing is im the second owner of this block, and i highly doubt the first owner did it. Because the first owner didnt even know how to take the block apart. :X
Yeah if you are going to do it, do it right and not with a dremel :rolleyes: Well, theoretically, if this were only going on a DUAL core, or a SINGLE die, the dimensions could be much smaller and would likely yield better results. For a single slug you could go 15mm x 15mm or so, this of course would apply more pressure to where it is needed. If you removed the IHS of a quad core cpu, the area that the 2 slugs occupy is 23mm x 14mm however I don't think a rectangular step would be ideal. If iandh could round the corners off a bit that would be great because if they are square, they are pretty sharp and mark up the ihs.
Kinda like this (not to scale).
noted.
Yeah im sending the block off to iandh. i want more mods on it.
I was thinkn of a thinner base, and drilling more injectors at the inlet so it doesnt hit a 90 first and then the injectors. I was thinkn angled drills at the inlet to the middle plate. :T
Well i guess im gonna let iandh have his fun with the block.
Originally Posted by Shoggy
Guys, my cuplex is normal. So it seems like eveyone elses is funky. :X
