:confused: :eek:
Provisional oops then.
I wont pop the heatspreaders on these, someone else can risk their RAM :p:
:confused: :eek:
I certainly understand :D
I'm very interested in the overclocks you receive from this product as it is easy to see if they are PSC IC's because that's all there is out there at the moment and they have the characteristic of a high tRFC (52) at Auto. They are not great overclocks either so if you receive higher overclocks than they do, then very likely they are not PSC.
tRFC is drawback for all 2GB sticks regardless the IC.
The NB might not be able to hack it- does strap, cooling or volts help any?
Im surprised this thread has so much interest, while my actual review thread has only a % of the views and replies :p:
There is no difference for the nb behavior regarding voltages/strap/dividers
when overclocking 2 sticks if they are 2x256 or 2x2GB.
If you arent going to feel better until you see a photo -- dont ask me to. Crucial switched to VERY sticky thermal tape and removed the clips. The small IC is fragile and I'm not killing a pair of 150 dollar memory. I've already done that once with 78nm micron on GEIL's.
You can see the shape of the 78nm IC, it is unique to Micron atm.
I can tell you that this stuff has ZERO problems running at 1066MHz @ 1.8V 5-5-5-15, rather impressive. The unimpressive part is its lack of ability to scale with voltage, similar to how D9HNL operates.
If you wanna argue about it more, go somewhere else, this stuff kicks arse :).
Bottom line - I dont have any other 4GB kits that can run at 1066MHz at 1.8V
no one post any screen shot?
are they trying to support that (red) charity thing or something?
Are the sticks on open-air with fan or inside case and with no fans?
I don't need a photo and did not ask you to show one. Sooner or later the truth will come out. As it is, I find it interesting that Micron is NOT posting any information regarding a release. Normally when Crucial releases Micron DRAM, they press release them. Nothing so far...
But let's face it. Results and performance are what matter. Taking 1066 at 1.8, add ~.3 - .4v to gain 84Mhz? That's what I call a diminishing return for me personally.
2GB Micron D9GMH @ 1200Mhz with 5-5-5-9
http://i259.photobucket.com/albums/h...08/36-1200.jpg
4GB Corsair 8500C5 @ 5-5-3-15
http://i259.photobucket.com/albums/h...kT2008/4gb.jpg
I'm fine with this set at any rate. Dropped my Northbridge from 1.4v to 1.2v. Transaction booster at level 1 works and this raised the throughput considerably. Would not work with the Microns.
Yes, I'm fine with it.
If they are powerchips the best you can do is up to 2.1V.
If not then they can scale up to 30MHz with 2.1-2.3V
That's what I'm referring to: http://www.newegg.com/Product/Produc...82E16820231145
So these definately do look nice then!
But I still want a set that can do 1200 mhz :p
i tried lower then 2.05v 1066 with mine GSKILL....no go :S
Does anyone know the price for the tracers when they come out? I am considering ordering the regular 2x2 ballistix kit. My G-skill 2x2 can't OC well at all 1:1 and I miss my old ballistix I blew out 4 months ago.
I want to get 4 gigs and if that works well, add another 4 gigs so I have no page file usage while emulating vista in ubuntu.
I'm expecting these to do at least 450 1:1, so that'll work out more than fine for my quad. If these bad boys can do 500 1:1, then I'm set and might try to push my quad to 4.0ghz again.
Since you won't pop em, this guy did.
http://www.cpu3d.com/content/view/4148/67/
Enjoy!
