Congratz Elmor! Good to see that you breaking WR´s!
Congrats Elmor :up:
//Andreas
Amazing Elmor ;)
EVIL SHADER OC and What a PSYKO SCORE :D
Fantastic scores and unbelivable shader's clock:shocked: :clap:
Very nice elmor, results with that setup = impressive :toast:
Probably the quickest strap. Imagine all that on a no CB LN2 CPU, 120MHz PCIe and some better RAM now... trying it anytime soon? :D
Wtf Insane Shader??
Great job, I still can't get over those crazy shaders!
very nice scores :up:
Gongrats Jon!
Sick shader clock indeed :)
3GHZ Shaders!!!! Congrats on .:WR:. elmor :clap:
Black Ops.. Man dat boards going to own a lot in near future.. aint it??
GTS and 270L of LN2 :shocked:
KP :up:
One question... How much shader raise score against core? Is it better to raise core or shader?
It's best to have balanced clocks, I believe they scale about the same.
Oh, btw. I tested the other GTS today :D
http://bandwidth.se/imgs/1/159/32gshader.jpg
http://bandwidth.se/imgs/1/159/card2.jpg
Dang Elmor, what's the secret to those insane core/shader clocks?
What brand are your cards and which driver do you use?
Insane clocks man! :toast:
Check topic :) They're ASUS TOP-cards:
http://bandwidth.se/imgs/1/159/asus8800gts.jpg
Stock speeds are 740/1800/1035.
The "secret" to getting highest possible clocks is to run about 1.5vgpu under load, really low temps (about -150) and keeping the PCIe-clock low.
I make vgpu and have one problem...If I put above 1.32v it just freeze in benchmark.It run all good until it have to show result,then black screen... What could be a problem?
Ridiculus shader's clock:eek:
No other words to say:eek: :clap:
Cooled by accelero x1 and some heatsinks for mosfet... Temperature never passed 60°C,never...It was also on the window and outdoor was about -8
And something else.If I bench 830/2072/999 it pass,but if I bench the same settings but with 1.35v,1.4v,1.45v it froze
These look like fun cards, thats good info on PCIe clocks.
Thanks elmor and congrats on the record :up:
Ooh these top versions are miles ahead of the vanilla version.
*starts searching for top version, vanilla GTS anyone? :D *
What memory is on those, qimonda or samsung?
How low is low for PCIe clock?
I used to use 115MHz, is that too high?
