can some1 link to the prime95 for quad... please... edit : nevamind :) its above
but then you go and add gpu's chipsets, mosfets into the loop and pretty much lose any advantage water may have.
I'm running my G0 on a single loop with a pa120.3, dtek fuzion and a D5 and I max out @ 57C when running Small FFT's in prime. Sorry bout the big pic
http://img184.imageshack.us/img184/174/85492292do0.jpg
when i loading 62c @ 3.2ghz with my b3 i wish i had a G0....
Ambients are high though...
i can get it 3.4ghz when ambients are a bit lower but still....
Temps stay the same if i had my fans @ low or high so that would suggest my rad is .......able to handle the heat??
whats the max i my cpu can handle under load??? 70c???
so is adding more surface area to a radiator going to give me a lower delta :)
not much +1
(lowering ambient and keeping it low would be much better = aircon room...)
10c is quite a huge temp diff! :D
would running pure alcohol help in the temps? :D
snicker...:p:
ok, suddenly I started to lie :rolleyes:
I was just being generous with the 10 degree difference. Seeing people loading at 60 degrees on water when my ambients are 28-30 degrees with my CPU loading at 65 degrees (g0 Q6600) @ 3.6ghz 1.50 vcore on a TRUE it just doesnt seem right? Watercooling seemed to have a much bigger advantage 2 -3 years ago it seems.
maybe you are half right or I am half wrong, looking the 4 cores I got mixed temperatures after prime.
http://i104.photobucket.com/albums/m...mperatures.jpg
55-57-49-52, ambiente should be 27º today. Is it impossible?
