Has anyone tried this with SLI yet?
No fix for 64 bit?
Did they fix the buy system bug where it changes to the default page every time someone interacts with a point on the map? Most annoying bug ever and it's been there since the first FP beta. Wasted so much P on stupid stuff because of this bug.
OK guys , finally i install the patch :D
:up:
How did you do it?
Two days too late here. I was stuck on the ATOL level and finally just uninstalled the game. There really needs to be an option in the "flying" controls menu to invert the mouse. The fact it isn't inverted to begin with is just dumb. I guess I'll never know how the game ends, but truthfully I don't give a crap.
Very easy
just reinstal game without Crak , then install the patch (wont ask for anything) and finally install the crack :cool:
the Game Saves doesnt work when installed the patch ( black image when load the Save) so we have to start the game all over again
few SS
Windows XP
Q6600@3.5ghz
Crossfire default
1680x1050
High
http://aycu39.webshots.com/image/374...4390439_rs.jpg
http://aycu13.webshots.com/image/371...0240470_rs.jpg
http://aycu06.webshots.com/image/410...4215807_rs.jpg
http://aycu01.webshots.com/image/414...9016543_rs.jpg
:up:
I was had never used the crack . . I'll grab the one from fileshack . .
well , for me it works :)
try this :
Greetings Community!
We have seen some people are reporting issues when trying to install patch 1.1 for Crysis. Following are a few early workarounds for you to look at.
1. Revert Back To Original Files
One solution is to revert back the original files your Crysis installation which include:
..\Crysis\Game\Localized: different language .pak file (use the standard langauge .pak you have when installing the game)
..\Crysis\Game\Config\: modified .cfg files (use the standard .cfg files delivered with Crysis)
..\Crysis\Game\Config\CVarGroups: modified .cfg files (use the standard .cfg files delivered with Crysis)
..\Crysis\Game\: modified .pak files (use the standard .pak files delivered with Crysis)
As alternative a clean and fresh Crysis installation might be the solution as well.
3. Install Problems Under Vista
In the case you are running Windows Vista and get an error during the installation please do following:
Right click on the Patch 1.1 Setup .exe file
Click on "Run as Administrator".
2. EA Download Manager - Install Problems
We are currently investigating and trying to provide a solution as quickly as possible.
Mascaras can you use -DEVMODE to show the exact site you are? I want to compare :up:
Got it . thanks
If someone didn't say it already: Crossfire works fine now :)
Good find. I will DL when I get home!!! :)
3-5fps when you are only getting 30fps is a pretty significant increase IMHO.
Oh, sorry. I tested it with 3870CF and Vista 32-bit DX10.
Does anyone on vista 64 use SP1 RC jst wondering if it increases performance.
Patch installed, my impressions:
Vista X64, Crysis64.exe, C2D E6600 3,3Ghz, HD3870 CrossFire 837/1201
- DX10 CF runs perfectly now.
- DX10 is slow as hell loading textures. I mean, in the beach level, you're seeing around, you look at a certain point, it's OK. Then, you turn 180º. You have to load the textures of that new place. It takes almost 2-3 segs to do it, and in that timeframe fps drop to almost 0. If you use binoculars, you have it too.
- DX9 works as fine as before, I can't feel any difference. This is the way to play Crysis, the texture load time is just miliseconds, not seconds like with DX10. And much higher framerate, 20-30fps more in certain places (beach for example).
- Some zones and levels just doesn't work with CF, like before. One good example is Relic from the beginning, or the village in Recovery. It's like the textures take ages to load again, and when they are loaded, perfomance is very very low, I think lower than single card. DX10 does not suffer this issue so far.
Just my 2 cents. If anyone can confirm this, better.
what you mean?? In Vista @ DX10 All zones and levels Work in CF without FPS drops ???
btw:
Few more SS @ Crossfire HD3870 @ Win XP @ 1680x1050 @ High settings
http://aycu17.webshots.com/image/389...4685359_rs.jpg
http://aycu11.webshots.com/image/412...4483701_rs.jpg
http://aycu19.webshots.com/image/382...3686643_rs.jpg
http://aycu39.webshots.com/image/402...8343565_rs.jpg
http://aycu20.webshots.com/image/385...8699622_rs.jpg
http://aycu37.webshots.com/image/388...0001732_rs.jpg
regards
What's that? Do I see a crosshair in there? (delta diff. level has no crosshair)
:P
