I was checking a e2140 tonight, it was flat. As far as I could tell it was flat, using a razor blade and holding it up to the light, there was no leakage, trying different angles across the top as far as i could tell was flat as.
I used the same razor on a GPU heatsink i was lapping on the weekend so i know the razor is good. Are all CPU's supposed to be concave or only some. I'd bank on that this one is flat. good temps too, 30's under TT BT idle 56 load.
