I really like what I've seen so far.
Major bugs/problems yet anyone?
after a crash the bios always reset oc settings.
if you completly power off the system for a ram exchange or something else the bios will reset too.
not really important but it's a little boring...
Yeah well, you just have to make extensive use of the F6 - F7 keys then I guess :D
But the old habit of forgetting everything when being completely disconnected from power really IS annoying.
Can you verify whether this happens if you just disconnect from power? Or only when doing sth else like swapping rams etc
scary to think phase reach those temps on watercooling
imagine having 1.9V+ on the quad on this board on Dice or LN2 eek
it will explode to oblivion lol :D
I thought he only had the cpu watercooled?
For stock cooling w/o additional fan blowing onto PWMs 70C is pretty impressive actually, if you consider his setup. These PWMs are stable at around ~110C anyway, so I wouldn't worry bout it. On the P965 QuadGT I get phase temps of 95-100C (thanks to my B3 Xeon) running 24/7... and this is on water - so they really did improve the digital PWM :up:
Living Review: http://www.clunk.org.uk/forums/revie...ng-review.html
On AB9 QuadGT, phases on water gives 60° when priming Q6600@3800@1.53V ;)
Results on AIR with a Tuniq Tower and a E6600:
Attachment 67113
OCZ Ti Alpha @ DDR 1000 @ 4-4-4-15 @ 2.35v
CPU VTT @ 1.6v
3dMark06 gives a 13153 @ these settings.........
Attachment 67114
With these settings the digital pwm's are about 60 C
I like this board so far !! Can't wait to put a Penryn in.
Any trouble fitting the Tuniq with this board I just orderd it and wanted to make sure :)
Thanks for that.....now ordered:up:
Have you had to update to latest bios yet [Ver 11]??
I am looking to put the latest on a USB pen drive in readiness trying to use the HP USB Disk Format Storage tool,......but it states "there are no valid DOS system files at the specified location" but all the bios files (there are files : RUNME; AbitFAE ; awardflash; M704B_11) are present ?? Will it work in any case ?:shrug:
Not if you're using unmodified mips waterblock... and yes I did tighten the screws properly ;)
It's made that way to prevent the phase chips from breaking but I guess they have overdone it a little... :down:
http://home.arcor.de/partywg2/Pics/quadgtpwm.jpg
Anyone with a quad managed to get stable over 400/410FSB without random BIOS freezes? Does your board need massive amounts of voltage to get stable at 400FSB and below?
This one of mine is really bad. At stock, I enter the BIOS and it freezes and needs a CMOS clear to fix.
I can then go to windows, and do whatever I was doing, restart and the BIOS has frozen again.
A friend of mine has the same problems, no doubt he will be posting soon.
Uh-oh. That doesn't sound too good. I guess I'll wait for a new bios then..
I mean, I can do 400 with my B3 and the old QuadGT w/o high Voltage (1,35V mch) perfectly well...
ut-oh!...doesn't sound good with the freezes...now...i am seriously considering the Gigabyte X38T board...hmmmmm...darn...it must be the same team that developed the AB9 QuadGT board...it wasn't very good in the beginnning with bios help.
I think there is something wrong with your board. I've playing around for three days now and cannot confirm your problems but i only have a E6600 not a quad. Yesterday i did 8*450 @ ddr 900 @ 4-4-4-10 without problems, the fsb wall on the E6600 is keeping me back, anything over 450 is not stable.
The bios sure isn't finished yet but i only get a freeze when i try oc'ing on the fly (F8) with the wrong settings.
I am getting good pwm temps (60-62) with the E6600
No mate, it is absolutely stock. Normally, I would have taken it off, and replaced with something else, but I didnt have anything that would fit - Being realistinc though, the PWM cooler is flawed, in so much as it really needs a fan to cool it, but unless you go out and buy one, the board will overheat relatively quickly.
I have seen 112c on the PWMs when only using 1.5v, and that was with a 92mm fan directly on the heatsink, and the board was built up out of the case.
I'm returning mine on monday, it has no redeeming features.
I would have said there is something wrong with it, but supershanks also has one, and his is the same, he also has a quad, but I will let him tell you of his troubles, if he can ever get back online :rolleyes:
If I were to speculate at what is wrong, I would say that the BIOS isnt ready for public consumption, and those PWMs need a better heatsink, or some kind of active cooling included.
Or you could try to fit one of the existing waterblocks onto the phase chips. From what I've seen so far, the PWM area is 100% identical to the AB9 QuadGT's. That's what I would try, anyways...
Oh really... that's about 20-30W max für the PWMs. Who cares - some people use dual laings, they heat up the water with more than that :O
20-30w? maybe at stock and idle, but if they do indeed hit the 80c+ that I've been getting, and there is 5 of them, certainly seems like more than that.
I have dual loops, but why would I want to add pointless heat into the loop? and also, why bother buying waterblocks for a board that doesnt work properly? :D
