What is the temperature at 3.2GHz? Does this chip run much cooler than the conroe at the same speed?
Wow that stepping is really weak and not impressive at all, I really hope that the rest turn out to be better. Although I would still take one and mess around with it HA.:yepp:
Thanks for sharing.
5279 for a CPU score in 3dmark06 at a mere 3.2GHz looks good to me. Of course that's from the perspective of a Vista user :p
This time I am going to treat myself and go QX9650.
All the tools, Coretemp, Everest and so on, don't work with this stepping of the cpu. So i don't know the real temparture.
The other steppings are better ;) Trust me!
Here some other benches at 3300Mhz:
SeLecT - 13770 - Yorkfield @ 3300MHz - 2x1024MB Crucial Value @ 589Mhz @ 5-5-5-15 - Gecube HD2900XT @ 860/963 - Cat. 7.10
http://service.futuremark.com/compare?3dm06=3480329
SeLecT - 194088 - Single HD2900XT @ 875/963 - Cat. 7.10 - Yorkfield @ 3300Mhz - 2x 1024MB D9GKX @ 589MHz 5-4-4-8
http://www.abload.de/thumb/aq37n9.png
It's not like the Conroe days where Intel needs chips leaking all over the place, they have the performance lead so there is no need for ES chips to work their way around.
A few seconds better than my older runs :D
SeLecT / Yorkfield @ 3326Mhz / VCore @ 1.504V / FSB 475 MHz / Teiler 4:5 / 2x1GB Crucial 594MHz 5-4-4-4 / Wakü / 13.828s
http://www.abload.de/img/1m3wnl.png
Cool, that beats my best effort 1M run at 3.6GHz with Conroe E6600.
At 3.6GHz this York must do some high 12ish seconds i presume...not bad.
Well due to the low multi I thinnk it's not that bad at all, 8 multi will be required to reach the clocks most of us get with our Q6600's...
Would be nice to see some clock comparison eg at 7 x 450 between this baby and my Q6600 and the gfx and co on stock... I would go for at least an 8X if the results are as promising as some hardware sites indicate...
Would it be possible to do 450BSB at 7x ram in Sync 900mhz at 5-5-5-15 no tweaks, no OC on the vidcard ?
I'll test my rig on thursday to see if there's really some gain to go Yorkdale from our GO stepping...( if there are results ofcourse :p )
thx in Advance
Just run what he did with his York (7x475 4:5 div 5-4-4) and do a 1M run to compare with your Q6600.
I bet you'll get 15sec at best.
edit:
Did a little comparisation myself, i think i have the same mobo (P5K-E):
What benches do you want to have?
I can test nearly everything with 450BSB at 7x ram in Sync 900mhz at 5-5-5-15. Say me, want you want, i will do it ;)
Yes, with my old E6600 or E6850 i reaches nearly the same time with 3,6Ghz. (~13,9xx-14,1xx).
Edit:
Thx for this comparisationscreen! :D
I never pushed my ram up so high, I never go above stock voltages ( 2.3 volts) as I cherish them too much :p, I own the Gskills PC8000 version 4-4-4-5, dunno if they also do 1200mhz (will give it a shot though) Also I don't like some Superpi scores as they are highly tweaked, on Iram drives and co really speeding up things, there was even a guy with an E4400 ( 3.6Ghz) beating my 13.129 score of my E6600@3825 with slower ram timings then me, never understood that... must be in the tweaks...
I just want to knwo if it's worthwhile if I can get a good price for my Q6600 next year to replace it with a Yorkie, or just to hold on to my cash for a little bit longer...
450 x7 FSB, ram at 900mhz 5-5-5-15 , no OC on the Vidcard...
SuperPI ( no tweaks :p )
Everest home ram benchmarks
3dmark 2001/3/5/6
Aquamark run
Don't need screenies just results...(maybe a memset screenie of how the ram is setup on the P5K-E as I won the P5K Dlx)
I need to install XP again on the P5K Dlx as Aquamark won't run on the 64bit version, take your time I won't be home till thursday...
danke sehr, freundlieche GruBen aus Belgien
This would be possible ;)
But AQ3 isn't good to compare, because with your 8800GTX or GTS your scores will be much better. :)
Bitte schön, und alles Gute zurück nach Belgien! :D
Just want to see the CPU score of AM3 :)
Ok, here are my benches with 3150Mhz to compare them with a Q6600 @ 3150Mhz.
Rig:
Yorkfield 2,33Ghz @ 3150Mhz (450*7)
Asus P5K-E Wifi
2GB Crucial @ 900Mhz @ 5-5-5-15
HD2900XT default
Benches:
3D Mark 01: 57653 Points
3D Mark 03: 38402 Points
3D Mark 05: 19417 Points
3D Mark 06: 12330 Points
Aquamark3: 181409 Points
SuperPi 1M: 14,641 seconds
Screens:
http://service.futuremark.com/compare?3dm05=3593902
http://www.abload.de/thumb/010djm.png
http://www.abload.de/thumb/03wsc8.png
http://www.abload.de/thumb/065dj7.png
AQ3: 181409 Points
http://www.abload.de/thumb/aq3yg6.png
http://www.abload.de/thumb/1mmehq.png
Everest-Benches:
http://www.abload.de/thumb/kopier4wy.pnghttp://www.abload.de/thumb/lesecdg.pnghttp://www.abload.de/thumb/schreibl57.pnghttp://www.abload.de/thumb/verzgerungutv.pnghttp://www.abload.de/thumb/testgr3.png
At least try 7x515 X(
3dMark06 is very nice there tho.
Perkam
7x515 = no boot :D
Thx :)
Here is a score with my old E6600 @ 3,2Ghz and no OC on the HD2900XT:
3D Mark 06 - 11040 Punkte
http://www.abload.de/thumb/3dmark06gv0.png
Damn cant be true :D something is holding you back XD [not even 500 sounds a bit of disa/ent.]
Thx for the benchies and screenies, at least I can compare what gives
No problem :)
SeLecT / Rendering 1 CPU : 601 Pts / Rendering 2 CPU : 1942 Pts / Yorkfield @ 3300Mhz / 471*8 / Cinebech 9.5
2*1024 MB DDR2-800 Crucial Value Micrin D9GKX (589Mhz @ 5-4-4-5)
HD2900XT
Asus P5K-E
http://www.abload.de/img/95pkar.png
SeLecT / Rendering 1 CPU : 3669 Pts / Rendering 2 CPU : 13127 Pts / orkfield @ 3300Mhz / 471*8 / Cinebech 10
HD2900XT
Asus P5K-E
http://www.abload.de/img/109tal.png
:D PLZ INTEL, gimme all of Your ESs right now............:ROTF:
My Q9550 has a max fsb of 455. 444 stable. Tested on an Asus Maximus Formula (401, 602, 701) and an Asus P5K3. I'm starting to think only the QX chips are good clockers. I hope I am wrong.
