Must be "low cost" pipes because even a VF900 on a GTX loads at 70C according to this thread
http://www.xtremesystems.org/forums/...d.php?t=159723
damn i had high hopes for this duorb as its not as big as that hr from thermalright. oh well
Great review thanx! So does that duorb work on HD2900s? I thought the 2900 had the same holes as the X1900 around the core.
Just installed the Thermaltake DuOrb on my Inno3D 8800GT and idle temps are 20C lower and 28C in Crysis.. Booyeah!!!
how good is 88GT on Crysis?
Leadtek 8800GT + DuOrb
http://img232.imageshack.us/img232/1520/037copyrz6.jpg
http://img524.imageshack.us/img524/7703/043eq9.jpg
http://img232.imageshack.us/img232/8372/055bc8.jpg
http://img524.imageshack.us/img524/7398/064wx7.jpg
http://img232.imageshack.us/img232/7008/076ap7.jpg
http://img466.imageshack.us/img466/1756/081ow5.jpg
http://img466.imageshack.us/img466/6...orbrun2eu8.jpg
Did you not put any heatsinks on the VRM's of the 8800 GT ? Sad to hear that the VF900 will outperform the Duo orb when mounted on a 8800 GTX. I wonder what would happen of you mount the VF900 on the 8800 GT.
i recently took the VF900 off my old x1800xl and it works well on my GT. Load temps of 65 max @ 756core/1890shader, in crysis, ati tool, and tabula rasa w/ all settings to max. I'm not talking just running 1 min at load, talking stabilized max temp - constant temp over time - flat line across.
Idles around 40-42.
If you don't mind. Could you do a Duo-orb vs AC S1 w/Yate Loon DS12L? Very nice work on the comparison.
i would really like to see a comparison of the DuOrb and VF1000. i plan on buying one of them and i would like to see how each cools a 8800 GT; right now i am going with the DuOrb
Awesome job!! thanks for the info....:clap:
I would pick the other one. The Duo only had two heatpipes. And when you put it at a 8800 GTX a VF900 seemed to be cooling better. Soms say it has low quality heatpipes. The VF1000 also have more heatpipes and you can also mount two fans on it so i would go for the VF1000 instead.
