Ok ,Air only @700mhz Gpu...Can go more,trying new Rivatuner n Nvidia driver..
A few weeks ago i was bottle necked by my stupid CPU/3Dmark glitch...It seems @3.5ghz 3dmark06 was bugged with my system...After hours and hours of tweaks i discovered that setting my CPU @3.49ghz was the only way3Dmark would then reconize it as 3.5ghz...I know ,crazy wierd problem. It will run properly @3.55ghz ,but i needed it set to 3.49/3.5ghz .I will be keeping my CPU @3.5ghz and any increase in 3Dmark06 from this point on will be all VideoCard:up:
GPU@700mhz A3:yepp:
Shader@1728mhz
Memory@2016mh
3Dmark06 Score Screen below.....
I hope this is OK for a 8800GTS320mb:D on Air onlyMy sig is max so far......This 3Dmark was run @700Mhz because im using new Nvidia driver and Rivatuner with the independant Shader Clock setting.
PS.Maybe the cards can be broken down into groups...
ATI
2900series
2600series
2400series
Nvidia
8800GTX/Ultra
8800GTS640
8800GTS320
This way you can easily referance your Videocard to its individual group,Just a thought.....By the way nice Overclocks, I wish i had more than 96shaders:D
http://i168.photobucket.com/albums/u...r320700mhz.jpg
