Originally Posted by
Pete
Wow, amazing dude.
One a few things i will chang
Pump mount, thicker stiffer so it's not bending!
Flip the NB and Mosfet routing round then you can lose that 90* to the GFX and have it direct.
Outlet from GFX make longer, it will be okay to touch the rad and loop back.
Micro res i'd get higer, it will feed pump more and higher it is add more flow and presure to the loop! Also trying to get a direct feed to the pumps inlet.
Every 90*is what 2ft extra tubing, so thats 6ft alone extra. Even if it's 1ft thats still 3ft extra to pump
This is my obervation from photos and i am not the expert you are as it is your rig. As it is it works and is perfect and is a credit to you for getting all that in there!
