It changes the drive strength.
I can't get past 500mhz fsb with the DQ6 at all. Just continuously reboots.:rolleyes: :mad:
I noted that when it does endless tries to post, switching on and off, it is a memory issue. By the way I am able to boot 500 Mhz + and I measured the memory bandwith to check the strap changes: with my system at 500 MHz it is very poor, 3900 MB/s vs 5700 MB/s at 390 Mhz.
Another story: was anyone able to regulate the speed of fans connected to sys1 e sys2 3 pins connectors?
I tried any bios combination and programs like speedfan but I never succeed in :mad:
I already tried that and no luck at all. :rolleyes: :confused: :( My memory has no problems running at 600mhz at 5,5,5,18@2.35v.
http://img516.imageshack.us/img516/241/cpuidzz9.th.png
Please post here a link to download as it isn't anymore on gigabyte web site!
Still no luck at all.:rolleyes: :confused: POS. I can get to 508mhz fsb but after that it becomes flaky even with memory running at 5,5,5,15 1:1. The memory runs fine at 600mhz at 5,5,5,18@2.35v no problem. Seem like a hardware strap issue.
http://valid.x86-secret.com/show_oc?id=202889
Still cannot post past ~525MHz FSB even with the CPU on water. Still have only tried 4GB of ram though.
you know a lot of CPU have a FSB wall before 500MHz...
hey can someone figure out if and where the mobo switches straps
I have to admit that reading other peoples experiences with other boards that this mobo would benefit from a more developed bios. But as a recent 939 convert I'm quite pleased with the performance I'm getting.
Roll on memset for the P35 too!
Anyone have this board and a Q6600? I just got mine today and am wondering whats the best bios working for quad?.
This SOB is going it the trash soon as it keeps on resetting to stock speeds after I restart all of the time. :rolleyes: :mad:
You mean after a normal restart, or an automatic restart after a bad overclock?
If the later, it wouldn't be able to boot with your messed up settings.
I see that all the time, and that's good.
Anyhow, today I had a complete reset, like when you click on that "load default settings" or whatever it's called in the BIOS, everything was lost. Anyone else seen this before?
I did + 643 on it :) (cpu fsb wall)
Think i have no luck at all with CPUs
Tried several of them:
E2140 max 380FSB (or 8*370)
E2160 max 370FSB
E6300 490FSB
E6320 500FSB
none of them can do over 500 :(
Hey guys finally I see some "action":
http://img81.imageshack.us/img81/6787/img1263by4.th.jpg
http://img231.imageshack.us/img231/1213/300x9yz5.th.jpg
http://img231.imageshack.us/img231/7...corepg9.th.jpg
http://img479.imageshack.us/img479/2...ore2ty7.th.jpg
Im on the stock cooler (with a few mods to make it quieter & safer) because my xp-120 didnt fit contrary to this artical:
http://www.legionhardware.com/document.php?id=643&p=2
This is a random overclock, I didnt want to go mad only having a stock cooler. Can anyone make sence of these temps? I set the bios to alarm over 70'c and I got an alarm when core temp 0.95 went over 70'c. Also in the first overclock I had the voltage options set to AUTO and it bumped the CPU voltage up to 1.4v with a lot higher temperatures.
Ill go for more if the temperature is ok. What do u think?
Edit 1.38v idle 1.36v load Orthos @3.15Ghz e2160.
Vdroop zero according to speedfan ( it does show movement when vcore set to auto in the first overclock):
http://img171.imageshack.us/img171/1...loadjb8.th.jpg
