Wow. On air and stock cooler. My god thats insanity.
if thats true i own one.
Edit - Didn't mean to sound like i dont trust you kinc, of course I believe in your results, what i meant was that if retail samples perform like this I own one.
:toast:
Kinc nice
hopefully i will get 8.37 tomorrow
http://www.nordichardware.com/news-pics/47.jpg
Source
//Andreas
I had a feeling it was going to be that way and with Sampsa himself more or less saying the same thing I am not looking forward to the gaming results with this card. If all you do is run 06 than this card is for you otherwise its Nvidia or another 4 month wait for ATI's 'refresh' offering.
Sampsa, can you say anything on if a Swiftech MCW60 can fit on the card or not?
ati went with stability first with the drivers.
Performance will go up.
hello again kinc, when you say without the shim do you mean the shim on the card itself around the gpu or the shim you put in to fill the 1mm gap , so as long as the gpu waterblock is bolted tight a thin shim may not be required, if you could confirm that that'd be grat, keep up the good work
Glen
Sorry I ment without the coldplate. The waterblock I am using covers the shim around the gpu wich is slighty higher then the die. I did a test where i first tightend the bolts like I usually do and wasnt quite happy with the contact. I tested too tighten a bit more (I stopped when the pcb started to bend;) ), and the contact was as good as ever. I am still recomendng you to use a coldplate so you minimize the risk of dmaging the card.
So Oc'ed the 8800gtx's will still hold the records for this round even in 06?
thanks kinc i have been looking all over for some 1 mm copper sheet with no luck so hopefully i'll get away with not using one, i know your busy but i appreciate you taking the time to answer, a pair of these should work well in my old p5w-dh , thanks again, you're still the man ;) Oh on a side note would you recommend using ram sinks on the upper side of the card as well,as the ram chips are on both sides on these or is this not really neccessary with these thanks
http://www.petrastechshop.com/2x2x1cobl.html
1/4" thick copper but only $6 and petras rocks
well this looks promising :)
Kinc goes subzero:
http://www.kinc.se/2900/1147.jpg
And this is far from the peak ;)
//Andreas
Can I get back to the earlier point about synthetic benchies vs real world gaming?
What do we think the real world gaming / 3d performance is gonna be like on these *mystery* cards...sky high or dive bomb?
