Hi guess2098, How you fix the problem with can't run 3D03,05,06 ,until it can run ?
Thanks for sharing :)
-nosysteminfo added after "x:\program files\futuremark\3dmark06\3dmark.exe"
I can't wait for good drivers... It looks very promising In my opinion :)
I thought ATI wasn't going to have a card to compete with the 8800GTX...
Can't wait to see some scores with new driver. We will be able to compare scores side by side and see how driver is maturing :) .
Ati Soft Eng have a lot of room for improvement in their driver for R600 ;)
Denny can you tell if this 1GB GDDR4 card is going on sale or it is another eng. sample?
PS. Bring more results PLZ! ShaderMark by any chance? :toast: for you!
will someone with a card please tell us if the mounting pattern is going to work with waterblocks currently on the market??? they look very similar but without having one it is impossible to know for sure.
thanks for the info denny and hope the new driver brings even better results.you know we appreciate your efforts and sharing your results with us. keep up the good work.
yea that was what i was dreading. damn. hm core only cooling. doh. anyone know what kinda heat gddr4 puts out? whether its necessary to really cool it or whether stick on ramsinks will do the trick?
8.37.4, packing date=4.19
driver improved some performance.
but ... even with 8.36.1 512m ddr3, 743/828.
cpu = 400*9 = 3.6G
05/06 is higher than urs @.@
Can you run a 3d01 nature denny? :)
Can anyone with an XT give us some hints to the temperature of the cards? Hotter or colder then say a X1950XTX @ stock under idle and load?
12,200 in '06 ? Not too shabby. I wonder what the GTX is scoring in your rig
with 8.37 driver on windows XP you can get +- that 2k6 score with a simple C2D 2mb cache @ 3Ghz and a X2900XT 512mb default :D
regards
