that was informativeQuote:
Originally Posted by Marci
thanks
thanks
good choice, the sloshing isn't a problem with the micro res and a powerful pump.Quote:
Originally Posted by Aldy402
Marci is right about the staining/fogging of the R3603 even without additives. I use only distilled and 5 drops of non-alcohol Iodine (biocide) asnd still ghave the problem a few montths later. All copper for me - no metal mixing either. I am about resigned to go with the black or silver stuff recommended earlier.
Thanks for digging into this Marci.
I thought the sound of running water was therapeutic.
I have always suffered with severe clouding. This time was the 3rd time I cleaned the whole loop, and I used zerex this time where I usually haven't... No clouding!... odd.
do you mean tygon 2001 Plasticizer Free Tubing?
http://www.tygon.com/Data/Element/No...00000000001498
2075 & 2275 are the two being mentioned the most in discussions with SaintGobain at the moment...
Any updates Marci?
I am in hopes of some information before I place my last order for my parts. This topic popped up just as I was getting ready to order my tubing.
Is as updated as it gets right now... have just emailed to see if they've gone any further...Quote:
Why not use the tygon beverage tubing B-44-3 It's Non-wetting surface permits thorough cleaning and complete drainage and should not absorb anything ! clouding is from the aditives penetrating the surface of the tubing ,If it dose not penetrate/absorb the dye's ect it will not cloud .
Why guess? Why not just use what they're recommending for use for our purposes, based on the chemical makeup of the additives that we tend to use frequently?
Guesswork is the reason everyone's been using R3603 for the past 9 years...
This has the potential to change the tubbing issues for good, thanks Marci. Subscribed.
Well this is what I found when I googled the name;
"ygon® 2075 Ultra Chemical Resistant Tubing offers an unequaled combination of chemical resistance, clarity and flexibility. Tygon® Ultra Chemical Resistant Tubing is virtually unaffected by acids, bases, ketones, salts and alcohols. It's entirely plasticizer-free, eliminating fluid contamination and the premature embrittlement and cracking common with many flexible tubings. Its exceptionally smooth inner surface inhibits particulate buildup and reduces the potential for contamination. Tygon® 2075 Ultra Chemical Resistant Tubing can be sterilized by Ethylene Oxide gas or steam in an autoclave"
Now in what sizes does it come, where can we get it and how much will it set us back?
Well im not exactly guessing here , this tubing is also used for water based inks used for printing . Ive asked a buddy that actualy use this at his work the answer i got was that the tygon beverage tubing B-44-3 dose not discolor from the water based ink and washes perfectly clean/clear . Now having said this i still not saying its the best choice or that the make up of the coolant and dyes we use wont efect the tubing diferantly than the water base inks . I am say its worth looking further into ! Im looking forward to your final analysis on this and just want to see all possible avenues explored !
Watching this thread. I was thinking of going with the old standby, Tygon R3603, but now I'm reconsidering thanks to Marci. :p:
I use tygon R3603, I use nothing but Distilled water in my loop, it has been now 3 months (well about 3 days shy) and there is no clouding on the new bits of tubed used and there is NO growth in my loop.
I wonder if people having lights inside thier loops effect Growth and/or Clouding? As I have none.
I'm willing to wager people with CCFLs have more problems with algae than those with 'dark' cases. Sunlight isn't really needed for photosynthesis, right? Just any sort of light at all would seem a harbinger of algae growth to me. I think in general it's a wise idea to put a few drops of a biocide in your loop (eg- PT Nuke).
What about if someone put in a UV light... To kill the bugs???
