Thanks for the update!
Looks like the non-Intel SF drives are a bit different on MWI, I've still got 27% (or 37% depending on how Intel handles the last 10%) left on my drive and NAND writes are up to ~380TiB.
Attachment 128490
Attachment 128490
Your intel 330 will go all the way down to 1%, just like my Intel 520 did.
Intel ported their method of measuring MWI to their sandforce drives, so the MWI goes all the way to 1%. Will be interesting if the 330 makes it all the way to 1% though .... did intel forget to set the NAND cycle feature to 3k rather then 5k on their 330 drives ... or does the 330 really have 5k NAND in it.
Also, if people are looking for a drive with Plextor M3 like performance, but don't have plextor stocking their part of the world ... keep an eye on the liteon drives.
I got the following from a $90 AU Lite-On - LZT-128M3S (128gig).
Attachment 128491
The scary thing is that inside the outer casing of this LZT-128M3S, there is a mSATA converter and a Lite-on M3M mSATA drive.
Such performance is completely nuts from a normal desktop drive, let alone a mSATA drive!
I could have checked how it was handled on your 520. (a bit lazy as it's holidays sort-of)
Here's a look at Reallocations vs MWI on the 330
Attachment 128492
Where the hell do I find such an oddball drive as that Lite On? That has my name written all over it.
Just keep an eye out for bargains. Then don't hesitate because they sell out quickly.
The Lite-on drives are very similar to the corsair performance pro and plextor m3 drives. 24nm Toshiba NAND on a Marvell controller. SMART parameters are very similar (if not the same) as your M3P that was tested. However, it seems that my drive is no good at counting power on hours. Been powered for 26 hours and only showing 1 power on hour. Could be due to some power saving mode.
@Christopher
I just tried to update fw on my Mtron but I just get this error message, both in IDE and AHCI. Got any ideas?
Attachment 128524
I used the 0.20R1 ver posted here this spring.
BAT,
No, my FW updates went off without a hitch, I just burned the ISO files to CD or on USB and booted. In fact, I can even update the FW of the dead MTrON (the one I don't fry). I got my Fw updates from Imation.
I've taken a look at their homepage but where can I find the download page with fw?
I ment Imation homepage. The Mtron homepage is down wich makes it not easy to find anything useful.
Were you trying to flash your MTRON with the Imation FW?
Samsung 830 256GB Day 120
(GiB) 2,945,117
(TiB) 2,876
(PiB) 2.83
(Avg) 297.81 MB/s
(B1) Wear Leveling Count: 12,761
(B6) Erase Fail Count: 9
(05) Reallocated Sectors: 36864
(POH) 2925
Nope, I used the Mtron fw posted here.
I've been desperately trying to find the 0.18 or 0.19 ver to see if that will make a difference
I'll try flashing one of my Imations with it.
Good luck :up:
Here are todays update:
m4
1239.4681 TiB
5174 hours
Avg speed 74.52 MiB/s.
AD 164 to 158
P/E 21325.
C3 4457
CE 58
MD5 OK.
Reallocated sectors : 00
http://www.diskusjon.no/index.php?ap...tach_id=497758
Intel X25-M G1 80GB
802.43 TiB
24461 hours
Reallocated sectors : 38 to 73
Available Reserved space: 51 to 49
MWI= 194 to 184
MD5 =OK
31.37 Mi/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=497759
Intel X25-E 64GB
526.13 TiB
1642-30=1612 hours
Available Reserved space: 100
MWI= 96
MD5 =OK
91.05 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=497757
Intel 330 120GB
554.08TB Host writes
2.00TiB Host reads
Reallocated sectors : 05 20 +2
Available Reserved Space : E8 100
MWI 35
[B5] 10
[B6] 10
[F1] Total LBAs Written 18156165
[F2] Total LBAs Read 65675
[F9] Total NAND Writes 399966GB // ~390TiB
POH 1345
MD5 OK
125.19MiB/s on avg (~217 hours)
Kingston SSDNow 40GB (X25-V)
1129.12TB Host writes (36999097*32)
Reallocated sectors : 05 61 // 1 up
Available Reserved Space : E8 98
POH 10079
MD5 OK
33.43MiB/s on avg (~217 hours)
I feel like the 830 should have more reallocations than just 9 at almost 3PB. But if we scale it down, it's a lot like the 64GB M4 with only .75PiB on it. Its even 1/4 the average speed of the M4.
Samsung 830 256GB Day 121
(GiB) 2,969,816
(TiB) 2,900
(PiB) 2.85
(Avg) 298.05 MB/s
(B1) Wear Leveling Count: 12,867
(POH) 2949
Sandisk Extreme G25 - 120gb - Day 45
Drive hours: 1076
ASU GiB written: 465,183.49 GiB (454.28 TiB)
Avg MB/s: 125.50 MB/s (70.38 hours)
MD5: OK
Host GB written (F1): 467,742 GiB (456.78 TiB)
NAND writes (E9): 349,098 GiB (340.92 TiB)
Retired Block Count (05): 4 raw
Failure count (AB, AC): 1 program, 1 erase
Raw Error Rate (01): 116 normalized
Media Wearout Indicator (E7): 10 normalized
Wear Range Delta (B1): 4 raw
Reported Uncorrectable Errors (BB): 0 raw
Been a hard week at work. Will be taking it out on a new SSD. Stay tuned!
I might start looking for another drive as well.
@christopher
Your Samsung has been performing better than expected, drives of such capacities are in a different league from smaller drives like 64GB drives.
I'm still thinking of creating an option for running at a reduced/fixed throughput and or combining with reading data on top of writing.
