My TJ09
http://i175.photobucket.com/albums/w...Picture015.jpg
that's sik darkatom i like alot post more pics
More Pics:
http://i175.photobucket.com/albums/w...Picture017.jpg
http://i175.photobucket.com/albums/w...Picture018.jpg
http://i175.photobucket.com/albums/w...Picture019.jpg
http://i175.photobucket.com/albums/w...Picture020.jpg
http://i175.photobucket.com/albums/w...Picture021.jpg
http://i175.photobucket.com/albums/w...Picture022.jpg
Really nice set-up there Darkatom. Makes me want to get a TJ09 and set my WC stuff like yours :D
This thread was the inspiration for me to make my OWN WC system.
Glowy tubes of water FTW!
( I think I've browsed this whole thread by now :up: )
[reserved for when I get it all together, hopefully by this weekend!]
Glowy tubes make me all wet . . .
leak testing anyone ;)
DarthBeavis, you're a nut! :D
darkatom,awesome rig man.. i don't like the tj09 but ur rig is an exception.
Well done!
Thanks for the comments :up: .
Decided I might as Copy+Paste my post from the Stacker Slacker thread...
Full pics/links to worklog and earlier mods:
http://www.xtremesystems.org/forums/...d.php?t=159734
Liquid Cooling:
D-Tek Fuzion (With a 1/16" O ring and a home made nozzle similar to Martin's... Also Lapped and re-bowed)
Swiftech MCW60 (Gonna replace the loose ramsinks later)
DDC 3.1 w/ Petras Top
Swiftech MCRES
Swiftech MCR320
Three Yate Loon SL's @ 5 volts
Tygon 7/16" Tubing
%100 D-Tek Hi-Flow barbs
Breeze aircraft stainless hose clamps
1:20 Ratio of water to G11
Overkill amount of PTnuke
Overkill amount of UV Blue Dye (I think i'm gonna add more to see if it'll do anything) :p:
Case:
Interior painted with Rustoleum "Hammered" Bronze "Jet Black" Paint
plexiglass added to Side Window and bottom grill (For noise and dust reduction)
4 holes cut in Motherboard tray to cable organization
3 Hard Drives vibration mounted Vertically
2x Yate Loon SL's @ 5 volts
Hardware:
DFI LanParty SLI-D
A64 X2 4200+ Mannchester 2.2Ghz @ 2.65Ghz
2x Patriot DDR500 1Gb
EVGA 7900GS @ 620 / 830 (Vmods soon)
OCZ GameXStream 600w With 120mm Scythe S-Flex added
2x WD740 10k RPM 74gb Raptors in Raid-0 formation
1x WD 200Gb IDE
Pioneer DVD-RW / DL (SATA)
5x UV 12" CC's
http://img222.imageshack.us/img222/4150/img0007ks4.jpg
http://img301.imageshack.us/img301/7457/img0001ky6.jpg
http://img219.imageshack.us/img219/3091/img0005yv5.jpg
http://img220.imageshack.us/img220/5760/img0006cr5.jpg
http://img525.imageshack.us/img525/4726/img0023ny3.jpg
http://img264.imageshack.us/img264/1854/img0027rm2.jpg
http://img229.imageshack.us/img229/1604/img0029mr6.jpg
http://img520.imageshack.us/img520/331/img0030ic3.jpg
Just wonder what are those graphic card pix doing here in Water Cooled CASE Gallery! thread ????? :confused2 :confused2
All black PCB's on purpose? Love it. :up:
Malik Excellent and beautifull Setup. I don;t see your Radiator.
Ha that is top secret :)
Mean seriously - radiator is on the front of case.
Nice Malik! But can i ask you something? Why do you use such small tubing? I think it would look 10 times better with Tubing such as Tygon 7/16" ID 5/8" OD...
I think about 10/12 tubes. But problem is with 90 degree fitting on my WC ( GPU, SB, Rez ). I can't replace them on simply fitting because then i must reorganize all set.
Malik, what radiator do you have stuffed into the front of that case? And how many of the drive bays are still usable?
